Question about Amana ALW480DA Top Load Washer
ALW480DAW Washer Doesn't spin
Washer doesn't spin, Clothes still wet after going thur the entire cycle.
Does it sound like a belt? What should I do?
  • 1 more comment
  • Patti Damon Jan 20, 2008
    How do you get to the belt, motor, brushes or pump?
  • tutor122 Sep 28, 2008
    Washer sounds like it's spinning but the tub isn't moving. What should I look for?
  • srosa12 Feb 10, 2009
    Amana LWA50AW not spinning...making loud clicking noise from pulley/drum interface (angled surfaces and spring loaded together) slipping past each other. Problem started after washing a heavy memory foam pillow by itself which caused imbalance and machine to vibrate across the room during spin and leaving a burnt smell behind.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Had same problem grab agitator and rotate it clock wise and you should hear a clinging noise and try again to wash, it should be fine
cost free for now
Posted on Mar 03, 2009
Access panel in frount, 2 screws to take out. if you washer is not spinning but washes try the tension pulley is not tight enough. to cured problem of not spinning if tension is not tight. check if the plastic pulley is turning if not get it loose and put greases on it. there should be a metal sleeve fasten in the pulley. but if it is rusted to the other shaft it spins on you will never know it was to be fasten in the plastic pulley. i broke them lose and greased tighten the spring and it should work good. time to time might want to grease it.
for the other person if you machine sounds like it is winding to go in to outer space, it most likely the bearings. they are 100 each and there are 2 of them. plus seals. i used mine for a year before i locked up, if you like the performances of that machine get it fixed. the $1200 front loader i just bought went back and the old AMANA is getting fixed.
Posted on Jun 14, 2008
There should be either an access panel at the rear or you could gain access from underneath. (switch off the unit b4 removing any panels though).
Posted on Jan 22, 2008
    Sergeant:
  • 236 Answers
Could be a belt or motor/brushes. or the pump is not getting the water out quick enough.
Posted on Jan 20, 2008
I have the AMANA washing machine model ALW489DAW
The washing machine is making a terrible noise when it is in
spin posision .I replaced the belt and spring
THANK YOU
Posted on Mar 15, 2008
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
Oct 25, 2011 | Kenmore 22422 Top Load Washer
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
On spin cycle drum going round but not spinning so clothes stay wet
Hi, if it doesn't spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jun 20, 2011 | AEG Lavamat 74640 Front Load Washer
The washer will fill up and go through the cycles, it will drain properly, but then the spin doesn't work proprerly. It does not spin at quickly, only very slowly and a knocking sound will occur. When...
Since you didn't say what brand and model you have I can only give you generic advice. If its a GE washer, it has a belt and sounds like it may be very loose or/and worn out. Other brands have belts as well. if it doesn't have a belt then a knocking sound could mean the transmission is out.
May 15, 2011 | Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Apr 30, 2009 | Amana ALW480DA Top Load Washer
Amana ALW480DA Top Load Washer Logo
832 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
