Mitsubishi wt-42311 green light flashes and turns
Mitsubishi wt-42311 when pressing power buttongreen light flashes and turns back off well it doesn't seem to start also when first gets plugged in it the light flashes i've called mitsubishi they some how made it work by me giving them serial number and model and my adress but it only lasted 5 minutes on what can be the problem
    President:
  • 1,214 Answers
Mits are bad about power supply capacitors failing. It can be fixed fairly cheaply, but requires some skill at disassembly of the tv and unsoldering/soldering.
Posted on Dec 10, 2009
42 mitsubishi how do you know power supply is faulty?
have you tried accessing the self diagnosis feature to see how manytimes the power indicator blinks after accessing ? If so let me know the blink code and I will assist you with the issue.
Oct 03, 2012 | Mitsubishi WT-42311 42" Rear Projection...
My t.v. dont stay on
First do a hard reset. Merely unplug the power cord for 4 hours, then restart it. This will correct it if the cause is corrupted soft codes.
If not, the protection circuit has captured the power management and you must have it looked at by a service tech.
Let me know if there is more.
Dont forget to rate me as fixya..
Jan 30, 2008 | Mitsubishi WT-42311 42" Rear Projection...
When i press power the timer light flashes and the T.V. turns on and right back off.
If model number is WT-42311 do the self check the set has.
When power light comes on and then goes off, on front of set press both the Menu and Input (device) buttons at the same time and hold for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and the repeat the code several times.
Let me know what the error code is and I will tell you what it means.
If this has helped you, rate this solution as very helpful as I do this here for free.
SD TECH
Oct 03, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311. Green tinted screen, now won't stay on.
Yes,the 2 STK convergence ICS and some or all the resistors,the pico fuse are dead.U know soldering,have the soldering tools,and solders right?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts,and labors.
May 13, 2010 | Mitsubishi WT-42311 42" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
My tv flashes a green screev when it turns on ,what is the problem?
Green tube,could be shorted video ic on Green CRT board maybe bad or adjust green screen drive control down.
Jun 11, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
and or the
convergence IC's (STK392-110) had failed and caused a diode (D522) to short
out.
If Q5A00 check bad there are other parts that have to be checked or
replaced.
Dec 02, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
