Question about Samsung SGH-x427m
Cant change time or date
No setting to change time or date
I cant change t time or date on my phone how domi do so?the model number is a207bg
the time should be set automatically.
if not, go to the settings and look for 'time and date' to manually change.
Jun 08, 2016 | Cell Phones
GPS 38 unable to access date and time in system setup. presently shows 1 jan 05
Hi John921,
Here is the step by step procedure to set date and time of your Garmin GPS 38......
It will definitely work......
Set Local Date and Time
1) Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2) Move the field highlight to the OFFSET field
and press Enter
3) With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4) Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
This will definitely work......
Please rate this solution............
Thanks......
Sep 08, 2008 | Garmin GPS
Cant change time on gps
the time and date should set it self when you turnit on, as long as the unit was designed for use in your area then it should set to the right time.
Apr 05, 2009 | Sony NV-U73T GPS Receiver
Date change on L200 digital camera
when you turn on ur camera press menu then go left until you're at settings. i think you'll be able to find it from there. if u cant then reply and help u more.
Aug 24, 2008 | Samsung L200 Digital Camera
Problem with initial set up palm
When you turn your Palm on, on the main page there should be a list of icons. Make sure in the upper right-hand corner All displays with an arrow pointing down.
Then, click on the World Clock icon to change the date/time for your Palm.
Jan 03, 2008 | Palm Tungsten E2 (Multilingual) Handheld
My MOTOROLA V3 clock on my phone is on military time
settings, INITIAL SETUP, time and date, turn off auto update, change from 24 hr to am or pm.
Nov 18, 2007 | Motorola Mobility RAZR V3
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Razr phone
well go to menu settings time/date settings and change it or it should automaticly change the time according to where u are
Oct 31, 2007 | Motorola Mobility RAZR V3
Time and date...
you can fix or set the time at the setting menu. look for time and date settings. from there you can adjust the time and date...
Oct 27, 2007 | Motorola Mobility RAZR V3
Samsung SGH-x427m Logo
50 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
