Question about Microsoft Xbox 360 Console
Graphical issues Last night I was playing COD4:MW2 and all of a sudden my tv goes to another screen with all red, blue, and white colors only. I thought it was just a minor error, so I waited for the next day and started playing again. Instead when I turn it on and get to the dash board, it goes all white and blue screen. I think it might have to do with the graphic card on the xbox 360. I've been having this xbox 360 since 2007. All the wires and plugs are still functional.
  • 22 Answers
A sign of the RROD send it to repairs.
Posted on Dec 14, 2009
SAMSUNG LD TV - VIDEO PROBLEM
Make sure that your video is connected to the video port on your TV. Also check to see if you are using the proper channel (component) on your TV.
Most issues occur when the cables are plugged into the wrong port. Some are color coded. Red goes to red, white goes to white and yellow goes to yellow.
Sep 18, 2016 | Samsung Televison & Video
Recently(within the past 6 months...) have been having a problem with my L37HDTV10A. The picture always takes a yellow hue. This applies to every input accross the board, and changing hue and color...
Hi.
A digital TV handles the color in three channels, red green and blue. Your TV has a problem on the red channel. That causes pictures getting yellowish. The computer functions can compensate the fault, but that is not a solution. If the problem happens on every input and also with internal tuner, then the logic circuits that elaborate video signal are defective. The main board is usually replaced to fix the problem. Before replacing the main digital board the technician can check if any repairable fault is found. A contact in one of the input for example may short the circuit affecting one of the color channels. In that case the tech will only need to resolder the connector on board to fix the problem. More commonly the whole board must be replaced.
Here parts for this TV: L37 TV Parts ' ShopJimmy
Regards.
Ginko
Sep 19, 2011 | Vizio L37 Television
I would like to play my Nintendo Gamecube. I have a Vizio HDTV. I also have a pdp cable the will connect to my Gamecube and TV. The cable has a blue plug, a green plug, a white plug, a yellow plug, and...
What you are trying to do is run your GameCube into the component hookups into the TV. What I would do first is lay out the five plugs on the end of the cord without them crossing over eachother. There should be a red plug directly next to the white one. The red one and the white one are both your audio hookups, plug them into the audio connections on the TV (that is the L and R ones and they are color-coded). The other three (green, blue, and the other red one) are the ones that are used to display the picture. Green goes into Y, Blue goes into Pb/Cb and Red goes into PrCr (again, the connections and the inputs on the TV are color-coded to make it easier). With that you should be able to play the system. If that doesn't work, make sure the red ones are in the correct place. Good luck!
Jun 29, 2011 | Nintendo GameCube Console
Installed a new set top box last night and all the channels are black and white - no colour at all - confused!!
vron63
Check your cables between the receiver and your TV to make sure the colors match. If you are using a component cable (green, blue, red, white, red), not matching colors at both ends will give you what appears to be a black and white picture. I hope this helps.
Ray Calo
DISH Network
Mar 09, 2011 | Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Cod4 'sometimes works online'
just wait for Modern Warfare 2. I play COD4 all the time and the problems are getting worse for everyone, not just you. Mine sometimes takes forever to get there, sometimes it doesn't and I have to restart, or the Playstation Network kicks me off a million times a night. 11-10-09 and COD MW2 will be out and then we can deal with all those problems :)
Jun 28, 2009 | Activision Call of Duty 4 Modern Warfare...
Ilo 42" Wide Screen LCD TV...Picture Malfunction
From some of the forum threads I've read about this, it seems like there were early issues due to bad firmware, but they have all be resolved with the recent updates. It also appears to be very easy to replace the hard drive. Just swap it out, format from the menu and you are done.
u will neeed to get it updated
Jan 25, 2008 | iLO 3200 32 in. LCD Television
DVD player not working right
Check your cables between your DVD player and the TV, this play has component video outputs that could possibly cause this issue.
Dec 25, 2006 | Sony DVP-NC600 Multi-disc DVD Player
Microsoft Xbox 360 Console Logo
106 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
