Large dust circle on a Toshiba 50H95 RPTV
After 9 years in ops, I notice a large "dust circle" on the center of the screen when displaying a light color background. It is livable and you will notice it.
Not sure if this dust build up on top of the glass lense. How do I get to clean it ?
I also notice this is a front panel I can open up right under the screen (and between the two speakers). Of course, it has warning about high voltage stuff inside the panel.
  • 8,617 Answers
No the front panel will only give you access to the CRT circuits. Remove the back panel. UNPLUG your set. You should be able to reach inside (its a stretch for sure) to clean the screen, clean the tubes and if you reach up behind you can actually clean the mirror. This will greatly improve your picture. Do not use windex just a damp soft cloth then dry with a soft cloth. The mirror cleaning is most important to get a nice bright picture. Over the years the mirror tends to get dull. Hope this helps.
Posted on Jan 20, 2008
To widen border on Toshiba lap top
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.If you cannot change the screen resolution then most likely the incorrect video driver has been installed.
Mar 30, 2012 | Computers & Internet
Tip
Wide screen monitor distortion Depending upon the screen resolution that has...
Depending upon the screen resolution that has been set in Display, the image will be distorted on these large wide screen monitors.
To correct this distortion.
1. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
2. Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle.
3. When you are satisfied then click apply.
on Feb 24, 2011 | Computers & Internet
FIX SCREEN RESOLUTION
Mar 14, 2012 | Dell OptiPlex GX260 PC Desktop
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Wide screen stretches all my photos
Dec 09, 2011 | Samsung Computers & Internet
We can't seem to get the green out of the television, please help
Sound like a bad degousing circuit. Try using a large magnet. Hold it near screen then do a circle 4 or 5 times last time hold near center of screen and pull away. You can also unplug unit for a couple of hours. Hope this helps.
May 10, 2011 | Toshiba Televison & Video
Red cirle in the center of my screen durning dark scenes
This sounds like the light engine has gone bad or has dust/dirt in the light tunnel or DMD assembly. The light engine would have to be removed to check for dirt. If the engine is bad it can cost over $800 just for the engine not including shop charge. Unit would need to be taken to a repair shop to find out what is actually causing the problem.
Sep 06, 2009 | Samsung DLP HL-P5663W 56" TV
Faint red blotches visible on light backgrounds on Sony KDF-42WE6
Convergence issues usually present as colors not lining up or a sort of "3D" effect like when you had to wear the green and red glasses. I'm no expert but it sound like you may have a magnetizing issue. You can test this by placing a large, very strong magnet on the "blotchy" area.
Slowly move the magnet in an ever widening circle. Pull the magnet back off the screen about an inch once you have circled the entire blotch but continue to rotate the magnet. Do this for about 5 minutes. If you don't see any change once you may need a stronger magnet or this is not the problem.
I had the same problem with a 6 year old Toshiba 50H13 and I found this tip online somewhere. I used a half dollar sized, rare earth magnet. I noticed a change almost immediately.
Hope this helps
Will Banks
Apr 02, 2009 | Toshiba 50H81 50" Rear Projection...
Yellow circle
there is a light filter on the blue lcd panel that is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical emgine.
Nov 21, 2008 | ASK Proxima DP6860 Plus Multimedia...
Sony KP-57HW40 57 in. Green Circles
well just remember the in the electrical industry its not 100 percent all of the time. you might just want to buy a new one.
Apr 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
447 people viewed this question
Top Televison & Video Experts
