Question about Kenmore 800 6983 Electric Dryer
I put in a new heat element and a new theromsat
I put in a new heat element and a new thermostat still no hot air
  • Kenmore Master
  • 2,699 Answers
You'll need a meter to read out your parts,if you read out the heater you would of known it was good and wouldn't of had to change it,check the thermal fuse located on the blower wheel housing,if your lint filter is inside the fuse is in the front,if it's on top the fuse is in the back,also if it is the thermal fuse you probably need a clean out,clean the duct out where the lint filter slides into,vac out the inside of the dryer and clean out the vent line if it's a long run blow it out with a leaf blower,makw sure the outside flapper is blowing fully open you should clean out the dryer like this every year so you don't have a fire
Posted on Dec 10, 2009
  • Sal De Dec 26, 2009
    when your checking to see what part is bad,first unplug the dryer,pull one of the wires off the part you're gonna read out with your meter,if the thermal fuse is good you have to check all the t-stats on the heater casing and on some dryers there is a heat relay and a motor relay and an even heat board located in the top console but you need to send the model number to know this,also make sure your getting 240 volts down to the heater, use your meter, like i just told you the problem could be in the console even a bad timer,you gotta make sure where the problem is first with your meter instead of changing parts out that are good and you'll save money and time
  • 112 Answers
Check your outlet for 220. with the back removed at the bottom or near the heating element look for a white plastic sensor. it will have two wires going to it. that is a non resetable fuse. you can unhook the wires from it --hook them together and test the dryer. that will blow out when you have bad vent air flow. DO NOT LEAVE THEM HOOKED UP
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Hoover dryer lights up element heats but machine wont run keeps saying clean filter ?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
Nov 22, 2016 | Hoover Dryers
I have samsung dv220aew/xaa dryer, that gets too hot and kicks code HE. New element, thermistor and cleaned thoroughly. Gets hot, codes on all heat settings. Any ideas?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Apr 21, 2015 | Samsung Dryers
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Feb 17, 2015 | Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
Oct 02, 2012 | Estate Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
Bought reliance 602 50 gallon electric hot water heater 4 years ago and it stoped heating bought new upper and lower elements and new upper and lower thermostat and still no hot water power goes to all...
did you turn the breaker on ? before filling the tank ?the water tank must be completly full before turning on. the new elements will blow if not submerged in water ..if you have 240 volts at the element and its not heating one is out .only one element can be on at a time so you really need an amp prob to test element .try an ohm meter an check resistance ,sounds like one element is out .hope this helps good luck /P/Swhen filling tank. open a hot water valve, on tub or faucet to remove air while filling the tank. you will hear the air coming out of faucet. when water comes out its filled..
Aug 23, 2010 | Heating & Cooling
Defrost heater not turninh on
That model has what is called a adaptive defrost on it this fails very often it is located inside the ref under the control panel, The only other possible cause would be a defrost thermostat, this is located near the heater.
Aug 11, 2009 | Maytag MSD2650H Side by Side Refrigerator
Not blowing hot air anymore
there are two thermostats..one above and one below the heating element..they probably need to be replaced..about 30 bucks canadian..have the shop check your heating element for resistance I had the same problem with my Whirlpool, when I called around for prices one shop suggested the thermostats and then tested my element for conductivity. When it passed he sold me the thermostat replacements(they are sold in pairs) They were very easy to install, just make sure the wires are on correct..Check for small marks beside the leads and then match them up while removing old and installing new. I hope this helps
Jan 18, 2007 | Zanussi TC7102W Electric Dryer
Kenmore 800 6983 Electric Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
