Question about Cozy (W352E) Heater
Wires not connected to gas valve need wiring diagram for Cozy wall vent heater
  • romyberry Dec 10, 2009
    It's a Multvolt system I have no diagram
  • Mark Egan May 11, 2010
    Standing pilot or electronic ignition? Powered with 120 VAC or no power? If no power, is there a wall thermostat (milli-volt operation)?
    President:
  • 1,214 Answers
I think you mean a milli-volt system. I went to the cozy heaters website and found the wiring diagram in an owners manual for a similar unit, a W355. I bet the wiring diagram will work for your.
Posted on Dec 10, 2009
How to install thermostat wires to furnace
that unit has a stat built into the gas valve, have to change valve to have a wall stat.
Oct 02, 2014 | Cozy (W352E) Heater
Have a Cozy 35,000 BTUH vented closed front heater with bad gas valve. Need to remove manifold from the valve. Is the valve a right or left hand thread.
on back of unit remove the 2 screws holding down the gas valve, remove wires and pilot tubing from valve, open side access door and you will see a brass nut turn counter clockwise and remove manifold and valve out the back of unit then unscrew the valve from manifold.
Nov 11, 2010 | Cozy Enclosed Front Console Heater 20,000...
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
My wall unit cozy heater goes on when I turn on the thermostalt but it goes out one minute later. What is the cause?
by pass the wall stat, pull the 2 wires off stat and twist together and if unit runs ok it is the stat if it does the same thing by pass the stat wire by disconnecting the stat wires from the valve a put a jumper wire between the (th) terminals.
Oct 10, 2010 | Cozy (W352E) Heater
Heater won't turn off. Wires were troubled
Shut off the gas to the heater. Bad gas valve. Gas should not be leaking from any part of the gas valve.
Oct 21, 2009 | Cozy (W352E) Heater
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy one sided wall furnace (no blower motor)
This is a weird one, but make sure all the wire connections are in the correct place. I accidentally miss wired a heater like this and it did the same thing.
Nov 27, 2007 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
1,133 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Paul
Paul
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
