Question about OKI C5100 Laser Printer
CAN'T FIND A DRIVER FOR MY OKI C5100 - OKI C5100 Laser Printer
The Vista 64 driver isn't all that compatible, but the C5150N driver works flawlessly. (The Vista driver will sometimes clear the screen almost like you've locked the console with a message about how the driver is trying to communicate with you. It works, kind of, but it's a PITA.)
Download and install the C5100 Windows x64 (or x86) driver from Okidata. Then, when you are installing the printer (or doing a driver update from the driver manager), you have to override windows by selecting the "browse my computer for driver software" option, then, "let me pick from a list of devices on my computer," and finally, "have disk..." Browse to the folder you installed the driver to, and when prompted to select the right printer, choose the C5150 driver.
Alternatively, if the printer is already installed, you can right click on it and select 'Printer Properties" (Be careful -- there is also a 'properties' and they are not the same thing.) Switch to the advanced tab at the top, and press 'New Driver..." and click "have disk...".
There's no difference between the C5150 and C5100 driver that I can tell, except that the C5100 driver is fully compatible with Windows 7 x64. It flawlessly works with my C5100.
Be warned if you disconnect the printer and attach it to a different USB port, Windows will reinstall what it thinks is the correct (and wrong) C5100 driver -- you will have to change it again.
I'm sure someone with the right knowledge could modify the .inf file for us, but it's not that hard to override windows.
Posted on Sep 08, 2012
  • 128 Answers
Do a google for it from the manufactures website ...
Posted on Dec 10, 2009
3 Suggested Answers
  • 3278 Answers
SOURCE: Our OKI C5100 is showing 171:Fatal error. What
The 171 Fatal error:
Upper Thermistor, State:Open
When an open circuit has been detected in the heat roller thermistor (low temperature)
Check the heater connector and the thermistor connector to make sure they are seated properly. If OK you probably need to replace the fuser.
Hope this helps.
Posted on Sep 03, 2009
davidj5684
  • 104 Answers
SOURCE: how do i install the oki c5100 without a cd
Go here and choose your OS then download and install the drivers.
http://my.okidata.com/pp-C5100n.nsf/openingdrivermenu?OpenFrameSet
After that you should be good to go.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Posted on Mar 04, 2011
Rear picture of c5100
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Jan 17, 2013 | OKI C5100n Laser Printer
How do i install the oki c5100 without a cd
Mar 04, 2011 | OKI C5100 Laser Printer
OKI C5100 printer Right side of printed page has repeat print. What do I have to do to get a clean copy without the duplicate print?
You have to determine if the drum cartridge or the fuser is the problem. Do a panic stop before the paper hits the fuser and see if it has the residual image. If it is clean then the fuser is the problem.
Feb 11, 2011 | OKI C5100 Laser Printer
When printing on my oki c5100 text or image - it prints fine but with a smudge/ghost of the image or text also on the paper. I know I need to order new toner - could this be why?
Open you printer and pull out the fuser assembly and look if the upper roller is fine because if it`s damaged it could lead to the double image.
Oct 20, 2010 | OKI C5100 Laser Printer
Code 356 Belt replacement needed for Oki C5150
By removing all the cartridges you'll find the belt. Replacing is very simple. Lift it out and put in the new one.
Jul 24, 2010 | OKI C5100 Laser Printer
I can not find a driver for my OKIC5100 for Windows 7 on OKIData website. Which driver should I use?
If you can't find a windows 7 driver try a Vista driver if they have one. The Vista driver normally works with windows 7.
Jan 05, 2010 | OKI C5100n Laser Printer
OKI c5100 flashing "K drum life" across screen. what does this mean?
"K" drum refers to Black drum Apparently the black drum has reached its life expectancy and needs to be replaced.
Apr 18, 2009 | Office Equipment & Supplies
Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Mar 16, 2009 | OKI C5100 Laser Printer
OKI Printer C5100 problems
probabily u have some message on the printer display, and your problem must be Toner low, u will ned to replace toner.
Jun 26, 2008 | OKI C5100n Laser Printer
OKI C5100 only printing cyan
I need to know if the test page that the unit prints as "Demo Page" comes out fine. If this is the case, your problem is within your application (software) or computer connection (check all cables). If this is NOT the case, I'll need to know more about your scenario. Operating system, type of connection (USB, parallel) and what are you trying to print. I'll be waiting.
Sep 27, 2007 | OKI C5100n Laser Printer
OKI C5100 Laser Printer Logo
239 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
