Question about Maytag Neptune MDG5500AW Gas Dryer
DRYER WON'T HEAT.
My Maytag dryer Model MDG3000AWW was not drying my clothing very well so I pulled it out to clean the lint traps all the way through the line. I looked in the hole in the back of the dryer and saw a lot of lint inside of the dryer. I reached in there with my hand and was able to get a whole bunch of lint out of the inside of the dryer (is this normal). I think went I pushed the dryer back into position, I jarred a wire loose because now it won't heat at all. I need to get into the dryer and I took all the bolts I can see out but I don't understand how to get the one piece (three sided) panel off. PLEASE tell me how to do this. I know I can fix this by putting the wire back in it's slot and cleaning the rest of the lint out of the inside of the dryer. THANKS.
  • ed61877 Feb 14, 2009
    Dryer tumbles, but the heat does not turn on
    President:
  • 1,314 Answers
Ok facing the drier front open thee door and remove the bolts around the door panel there are four of them two on each side then grasp the front about 3 inches down on either side to disengage the side retain clips tilt the panel back toward you and lift it up to disengage the bottom clips remove the front panel and if you need to lift the top remove the screws on the hooks on either side at the top and take the hooks off then you can lift the top that should give you plenty of access to do what you need to do
Posted on Jan 20, 2008
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
My 1993 Maytag Clothes Dryer heats up, turns but does not dry the clothes unless I place an absorbent towel in with the items. It sweats water from the bottom of the dryer. What is going on?
To dry clothes, we need 2 things:
1-heat to evaporate the water from the clothing
2- adequate air flow to exhaust the moist air, thereby drying them.
Your heat seems to work.....if you stop the dryer mid-cycle, the clothes should be hot.
It sounds to me like you have a lack of air flow through the dryer. If you can get to the exhaust vent grill outside, then see if you get a large volume of air coming out of it. If not, then look for the louvers stuck closed on your outside grill, or any kind of blockage in your ductwork.
Perhaps undo the vent at the back of the dryer TEMPORARILY
Mar 20, 2013 | Maytag Dryers
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Dryer is not drying the clothes
If it is taking a long time to dry, but still has heat, try cleaning out under the lint trap. Take the whole lint trap off and clean the panel and path the lint is sucked through. I did this to mine and it made a HUGE difference! There was a ton of lint packed around the panel and only a small opening left where the air flowed into the exhaust.
With our dryer (Maytag) I had to take the front panel off to get to the area where the lint was.
Jan 19, 2013 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
My dryer runs but no heat.maytag neptune gas dryer.
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Maytag Dryers
Dryer is not heating up to dry the clothes
Good Luck!!
Sep 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clothes not dry but dryer turning. cleaned out
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 09, 2010 | Roper RGX4634KQ Gas Dryer
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
564 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
