Question about HP Pavilion dv6000z Notebook
I have a hp laptop but the problem is my battery charging. it say plugged in, and charging. but it will not charging at all my battery in my laptop. but when i charge it my battery to other laptop, it will charging.
  • 128 Answers
The battery is bad get a replacement...
Posted on Dec 10, 2009
4 Suggested Answers
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Posted on Jan 09, 2010
  • 5 Answers
SOURCE: Dell Latitude D600 won't accept charger
Tienes un problema con tu cargador el cual tiene un voltaje de referencia que no esta entregando,, y por eso no entra la carga de tu bateria.. la manera mas facil de resolver esto es cambiarlo . economico y barato seria esto,,
Posted on May 31, 2008
  • 8 Answers
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Posted on Apr 28, 2009
HP Mini 2140 "Plugged in, charging" but not charging
Hello jorel, most likely its a failure of the system board particularly the charging section, a broken pin or a loose terminal. work will be internal, suggest you do away with the battery. its better to operate it at home, or bring the charger with you. Maybe its time to get a new one.
Dec 05, 2013 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Elitebook 2530 Pindicator says battery charging but battery not charging
Could be a back power brick or DC jack yes. Power off the computer and remove the battery. With the battery out plug in just the power brick and turn on the computer. If the computer doesn't power on gently wiggle the plug into the laptop and repeatedly hit the power button if it comes on briefly then off again you dc jack is loose. If it doesn't come on at all then its the power brick. If the laptop comes on gently wiggle the plug into the PC. Powers off while wiggling DC jack.
Jul 09, 2012 | HP EliteBook 2530p Notebook
Pavillion dv4 new battery only charged one time.
How long did you leave the battery for charging?
Dec 29, 2009 | HP Pavilion dv6000z Notebook
Is there a problem with my laptop battery? I have a HP PAVILION DV9000 laptop which is nearly 6 months old and today, when I plugged it in it said "40% available, plugged in, not charging" I don't...
Mine is a Dell Laptop but I think yours has something like mine.
pull out your Hp pavilion dv9000 Battery to check its charge checker... its like a button in the battery when press will give you the amount of charge in the battery by, charge level is presented by small LED lights.
for your laptop side, default settings is very good actually, so try to revert back to default settings. Changing pavilion dv9000 Battery is expensive and I don't see any need in it, if you have been using your laptop only for 6 months.
Dec 04, 2009 | HP Computers & Internet
New hp laptop battery will not charge w/plugged in AC and turned
You probally have a dead motherboard port that charges the battery.
Sep 26, 2009 | Dell Latitude D600 Notebook
HP Laptop Battery Problem
I had a similar problems and I had my batter replace by Hp free of charge. Most like your batter could be damage internally or it could be a motherboard problem.
I suggest you visit this HP link http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Jul 03, 2009 | HP Pavilion dv6000z Notebook
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
Your battery is dead when it no longer will hold a charge. Replace your battery.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
Battery life is very short
Not really. What happened is you shorted the life of the battery by always having it plugged in and in a charging state. The battery has a memory and since it's always been plugged in, it will never charge fully. There are products out there that will drain your battery down and reset the memory issue. But it would be cheaper to get another battery. If you are going to keep it plugged in the majority of the time, charge up the battery and remove it.
Jul 25, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv6000z Notebook Logo
162 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
