Question about RCA Televison & Video
My RCA D52W20 will not power up. When the set is first plugged in, the power on LED stays on for a few seconds and then goes out. It does NOT do this three times. After a few minutes, you can push the power on button and the led stays on for a few seconds and then goes out. I replaced CP150, CP114 and CP120. CP150 tested good on a capacitor tester. The other two failed the leakage test. The symptoms are still the same.
  • RCA Master
  • 5,807 Answers
These time , since you have changed the capacitors, check the horizontal
output transistor .
Check for resistance first, it might be shorted.
These transistor have three ( 3 ) pins namely the base , collector and
the emitter.
check for the collector ( center pin ) and the emitter pin ( rightmost pin)
the base and emitter is usually shorted ( if connected on the board due
to the HDT connected )
Assuming that horizontal output transistor is replaced and still not
working, you might need to measure the B+. ( can be the voltage
at the collector of it.)
If the voltage reading is more than 140V, horizontal oscillator is
block.
If the voltage reading is 75 V , the flyback is partially shorted, take
down the flyback part number and have it replaced.
Try also resoldering the pins of the flyback might help.
If you have a bright light and a magnifying glass then you can/ might
see more cold solder joints.
Might as well check again the polarity of your installed capacitor
just in case.
The B+ can be from the chopper secondary output after the positive
side of the diode. It is mounted on the aluminum heatsink.
The horizontal output transistor is also mounted on an aluminum
transistor.
Posted on Dec 11, 2009
  • Rommel Cana
    Rommel Cana Dec 11, 2009
    these might be similar to yours
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can u help me my RCA TV will not stay on keeps turning off.
Palaboy, where can i buy this part at ? R73 .0087uf h 2000 vdc. the one in red rectangle.
Jan 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Switch on goes off switch on goes off switch on goes off then sta
replace the flyback # 259296 you can get the 259296 flyback replacement kit at the following link which contains the flyback and the CD with detailed instructions for the repair.
http://www.tvrepairworld.com/
Jul 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't stay on
Hello mrscarpenter,
This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need solution
Appreciate the direct "Ask Me".
Your concern with an RCA D52W26 is when you attempt to turn it on, it powers up as indicated by the LED lights but they then power OFF a few seconds later? or it powers on then you get to see bright line(s) left to right, then the TV powers OFF? or it powers on but only bklinking LED lights? If yes on the last any sequence to the flashing/blinking?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Projection TV
ok lets begin... shut off? ...is the set staying off. NO POwer at all.. does the set try to come on. does the set have a blinking led on front. have you tried unpluging then waiting 30 min then trying to turn it on again.. this set has a processor and when it detectect any fault will shut the set down
Mar 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
32 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
