Question about Watches
HELP !! can't snap armitron watch cover back on
I popped the back off of my Armitron wach to replace the battery and now it won't go back on. It acts like the back is slightly too big to snap back in.
  • 5 more comments
  • Anonymous Apr 09, 2008
    Me too! Did you find out how to do it?
  • rfcjr May 30, 2008
    I have the same problem. I cannot get the back on the watch. Any help?
  • mustlx90 Sep 26, 2008
    I just want to thank the last guests for your help with trying to fix this. I actually kept it all this time with the hope that it could be fixed. That trick with the quarters and the paper towel really works to keep the crystal from breaking. I squeezed the hell out of that thing. I kept moving the pliers to different spots to see if that would do it. I forgot to put the quarter on the backside of the cover. I dented it and ended up giving up and throwing the watch out. This will be my last Armitron watch. I destroyed the twin to this watch by trying to force the cover back on after changing the battery. I wish good luck to the guys that wrote in with the same problem. I hope you get yours fixed.
    Thanks again .........
    Mustlx90
  • Anonymous Dec 02, 2008
    The Quarter method is bull It shattered and ruined my watch.
  • Steve Caudell
    Steve Caudell Nov 01, 2011
    Can someone please post the trick with the quarters?
  • lspanenberg
    lspanenberg Jun 08, 2012
    Worked very well. I tried everything to snap the back on for a few months. It was going to be $65 to have it done at the jewelers. I thought this would be a great last resort. I was careful to not squeeze too hard in the center as the citizen watch crystal is domed. I applied pressure a few times from the sides. It did not "Snap", but when checked, it was securely fastened. Thank you for sharing this great idea.
  • smittie2008
    smittie2008 Jan 16, 2013
    Nobody wants to hear from someone who has the same problem. Why do you think we're at this web page to begin with? For a chuckle?
Take a small thin piece of cloth or paper towel, fold it and use to cover the watch face.  Put one quarter (coin) on top and one quarter (coin) on the bottom.  Place the sandwich in a pair of pliers, center thhe pliers and press, when you hear the snap, the back is on.  Do not use on a watch with a domed crystal, or at least use a lot more padding over the face.  Takes 10 seconds.
Posted on Sep 22, 2008
  • 3 more comments
  • norem Feb 11, 2011
    I just tried this with a paper towel folded 4 times (16 layers) and busted the glass although the face had a flat surface (i.e.not domed).This is actually a good idea but obviously not fail safe,so try it at yourn risk.
  • dee sleezy
    dee sleezy Apr 10, 2014
    anyone who is dumb enough to use a coin that is smaller than the glass deserves to have thier watch break.... morons
  • Rhonda Kozan May 29, 2014
    This is the best technique- and from reading several suggestions here and else where I recomend this solution. Not only did this work perfectly, but I was left with a feeling of success and duh of course,how could I not think of this ....
  • Caleb johnson Aug 18, 2017
    Yeah thanks for that. Followed all instructions and shattered my $200 armitron and broke it. Same technique broke my $75 polo watch too.
  • J Evans Mar 29, 2018
    I didn't think it would work -- and I tried a few of the other solutions. But this did work: kleenex padding on face, quarter on top of padding; quarter on back, pair of pliers. Presto. It's back on now. Thanks.
  • 7 Answers
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
Posted on Aug 27, 2009
I used a wash cloth, quarter and a beer bottle. 1st you fold the wash cloth a couple of times, put it on a table, put the watch face down on the wash cloth, drink the beer because your frickin thumbs are tired from trying to press the back on, line up the back noting that some watch backs have a cutout for the stem, put the quarter on the watch back, put the small end of the beer bottle on the quarter and give the bottle a smack on the bottom, you might have to move the quarter around and smack the bottle a couple of times to get the back to pop on fully.
Posted on Mar 04, 2009
I was having trouble with this too, but after my wife and I played around with it for awhile it suddenly seemed to snap into place in the side opposite the notch I used to open it.
After that, it just took some moderate pressure with my thumbs right up near the corners by the notch to snap it the rest of the way in.
It seemed very unlikely I'd would have been able to open the thing if it really took the amount of pressure all of these previous posts said. I think it's all about position and there is no obvious way to tell when it's in the right position, other than it just snaps into place. Patience and persistence is all it really took.
Posted on Sep 10, 2010
I tried off and on for 2 months trying to get my back on my Armitron watch, finally I put my watch back in a plastic bag and put it in the deep freeze for 30 minutes, with about 10 minutes left for the watch back I set up on a counter top a paper towel folded several times, then I got out my space heater and warmed up the watch, not too hot, but fairly warm. Once The watch was warm I placed it face down on the paper towel then I quickly removed the watch back out of the freezer, with minimum handling I placed the back correctly on the watch, with a fair amount of pressure from my thumbs I was able to snap it back on.
Posted on Dec 15, 2010
  • Jeff Urkevich Sep 02, 2011
    I'm considering a sledgehammer to put the back on my Armitron! I've tried everything!
My solution is NEVER buying another Armitron watch. I am having a problem putting mine back together right now. I paid five dollars for the battery. It's not worth investing any more money on this piece of "made in China" junk.
Posted on Feb 06, 2010
  • bleachboy Jul 22, 2013
    Amitron is an American company, that's why it is junk.
I just did the following:
Take a piece of smooth wood
Place watch on it, glass side down
place a wooden ruler (thick one) across the back
Clamp the whole thing and tighten
Note 1: you may not hear a click so check
2. Do not use any clothe between glass and wood, this will make teh force uneven
Posted on Sep 08, 2010
I was just having the same problem with an Armitron watch... this post and the comments didn't make me feel much better.... but I just managed to get it with 2 quick grip clamps... the clamp faces are rubber padded and I got the watch for 20 bux at tjmaxx 5 years ago, so I didn't bother with paper towels or anything. You just have to not be too afraid to break it... that being said... entirely possible I was on the verge of breaking it... but I finally got it and it's ticking again with the new battery.
Posted on Jun 13, 2010
I used a 3/4" PVC pipe fitting with a diameter slightly larger than the glass face. I placed it in a wooden clamp (Jorgensen brand) and with slight pressure it popped into place.
Posted on Jul 29, 2012
Make sure the cutout of the stem is alligned properly and also start opposit of the point you pryed it open.
Posted on Sep 07, 2008
  • ulamthelucky Sep 10, 2010
    This is the correct solution. No Vise, pounding, beer bottle needed.
This will work if you have a pair of channel locks at home (You'll find one in most too boxes). You'll also need a 2$ coin, cushioning (paper towel worked for me) and a table or flat surface protect the crystal side of the watch (a wooden kitchen cutting board worked for me). Put the cushioning on the cutting board or flat surface, lay the watch face down (crystal on the cushion), then put the 2$ coin on the cover side of the watch on top of the cover. Press everything together using the channel locks and voila! Problem solved!
Posted on Feb 13, 2018
    New Friend:
I spent ages on this, putting the watch back in the freezer didn't work (and it's probably not a good idea anyway due to the condensation which forms when you take it out of the freezer. What did help was getting my teenage son to help - we could press both sides together and after a couple of tries, sorted!
Posted on Nov 15, 2016
    New Friend:
    Problem Solver:
  • 9 Answers
Pliers? Pieces of wood? Beer bottles, quarters and plastic pipe.... What a great set of sketches for a show. Anyways, let me set everyone's curiosity to an all time high when all you need is lump of what we in the UK call Blu-Tac, (I think in the US its stick tac or plasti-tac or something but the same stuff). Well here's how...
1: Roll a golf ball sized piece of blu tac around in your hands till it's warm and pliable.
2: push the face of the watch into the tac up to its depth. Repeat this process for the watch back.
Leave them in a cool place for 5 mins (a fridge is ideal) or untill it's become firm again. Now comes the fun part....
Line both up squarely, place on a carpeted floor (don't worry the blu-tac won't stick) then using the front 'ball' part of a bare foot, GENTLY step onto the watch. Your feet are one of the most sensitive parts of your body & you'll FEEL the moment it clicks back together.
Now if you've followed this tutorial exactly, you'll need to REMOVE the back again. Now you're right back where we started only this time, POP THE NEW BATTERY IN THE WATCH FIRST.
Posted on Jan 09, 2016
    New Friend:
I just tried using thick cloth and pliers based on the above comments, got the back on alright....shattered the crystal and apparently messed up the hands...yay! Salvaged the new battery and managed to cut my finger in the process. Thanks armitron for 10 months of sparkle before your cheap battery petered out. }:-(
Posted on Sep 30, 2015
I was able to do it without breaking anything.
1) To avoid any contact with the watch glass, I placed it on a seweing line roll. It fitted the watch size so that only the borders of the watch were touching anything
2) I removed one pin of the watch bracelet, in order to make it easier to access the back of the watch
3) I placed a stick of wood on the back of the watch and hit the wood
Posted on Sep 01, 2012
Need to change battery in Armitron Now ladies watch 75/2475. How to do it. How to you remove the back on the now 75/2475 watch
Take your Armitron watch to a jeweler for a demonstration of how to open it. While there, you may be able to persuade the jeweler to install a replacement battery, all for a reasonable sum.
Feb 10, 2018 | Armitron Watches
What battery does an Armitron 20/3274T watch take?
Take your Armitron watch to a jeweler for battery identification and possible replacement.
Oct 07, 2017 | Armitron Watches
Armitron watches need to know how to change battery
  • Remove back
  • Find battery location. Note mounting and polarity for later reference
  • Identify battery type
  • Obtain replacement battery
  • Remove old battery
  • Install new battery exactly as noted in second step
  • Check operation
  • Install back
  • Set various functions
Aug 30, 2016 | Armitron Watches
How do I get the back off of a 1980s Armitron pocket watch?
the back on this pocket watch will not screw off if there's no notches for a unscrewing tool to go into, if you very carefully go round the slit with jeweler's loup you should see a small groove were you can get a stanley knife blade in the pop it off .good luck.
Nov 05, 2015 | Armitron Watches
New watch won't start
Maybe the battery is bad? If its new take it back to where ya bought it and tell them. Most places will replace of fix it. I would check the battery.
Aug 11, 2012 | Armitron Watches
I took the back of my armitron watch to replace my battery and now cant get it back on
if your watch is a snap on type of caseback and it is round, it is difficult to push it back or close it you have to use pressing tools. if you don't have it, you have to bring it to watch service center to close your caseback. because they have it. i hope i had been helped you.
Sep 13, 2011 | Watches
My question, bought this diamond accent watch but the little snap thing that hold the watch band snapped off about 2 weeks after i bought it,got it at wal mart and they wont take it back, said its not...
If you present your watch and receipt for it the shop has a responsibility to repair any faulty parts. If, however, if it has been damaged, then they are under no obligation to repair/replace it.
Aug 03, 2017 | Armitron Diamond Dial Watch
How do I change battery on my gametime watch? how do I remove back casing?
My GAMETIME watch has a back which just pops off. Once in the battery compartment, you will see plastic disk, with a molded frame. This just simply pulls off, and is not secured in place. You should not have to pry it.
Once this is removed, the battery is revealed. My model takes a SR626SW. To remove the cell, use something small to get under the exposed side. You should be able to pop the cell out without much force.
Before you replace the battery take this opportunity to clean the rim where the backing was. Carefully install the new cell, and replace the cover.
Sep 21, 2010 | Gametime Watches
Have new battery installed, can not get back to snap back on.
You will have to take to a local jeweler who has a watch press.
Sep 01, 2010 | Armitron Blue Dial Stainless Steel Watch...
Armitron y121e watch
If your Armitron has a set of 6 inset notches around the back, as does my Y121E 20/1791F Armitron Diamond, that's a screw-back case that does _not_ pop off or pry off. You'll need a case opener tool, which is basically a small tool with adjustable-gap jaws that fit into two notches on opposite sides of the case and let you unscrew it. Wal-Mart sells this tool for about five bucks, and it'll pay for itself soon enough, as many watches have screw backs, and this will fit most anything you find. Head for their jewelry department and you should find the tool hanging up with the replacement watchbands and batteries.
The case is probably screwed down fairly tight against its O-ring seal, so make sure the tool is seated properly in the case notches, and turn it slowly and firmly counterclockwise to work it loose.
If your watch is like mine, it'll take a #377 cell, but wait until you've opened yours up to be sure.
Sep 03, 2008 | JCPenney Armitron Sport Link Bracelet...
Watches Logo
24,135 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
