Question about Dual Electronics CECT P168 Cellular Phone
The touchscreen on my voyager t737b has stopped working in places, i tried a factory reset thinking it was software based but now i'm stuck on the caliberation screen on startup. the screen has developed a bleed under the top layer f the screen, could this be responsibe and how do i fix it?
  • espio_silver Dec 11, 2009
    i'm stuck at the calibration screen.. i cant get past it. it wont calibrate and theres no other option after a factory reset
  • 61 Answers
Hey, try this way: Setting - phone setting - pen calibration
generally it will be fine after you finish calibration.
ask help from your supplier if still can't work. Good luck.
also you can visit www.eshopbing.com if you like. Tks
Posted on Dec 11, 2009
SOURCE:
Tmax 9 tablet stuck on boot screen
  1. Shut off tablet
  2. press the volume minus button and the power button @ start up
  3. tmax logo shows up and then a android menu
  4. factory reset
  5. Once complete, reboot
  6. wait 4-5minute... tablet works again
Dec 26, 2013 | Tablets & eReaders
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
Ello My problem is when i boot after a factory reset i have touchscreen to calibrate and when i do it it gives me try once again it's stuck there
I am not sure you are talking about a tablet PC or the new craze of tablets.
For the tablet PC you should have a screen calibration utility. You can calibrate the display for the Wacom (or other) pen, or for the touch input.
When you calibrate the pen, any touching of the screen with anything other that the Wacom pen will be ignored.
Similarly, when you calibrate the touch, any input with the Wacom pen will be ignored and you will be asked to use the proper instrument.
To get back to your case , it is possible that you are not putting the finger at the right place or not pressing hard enough. That is just a guess and I may be off the mark for the new tablets, but not for the Tablets PC:
Apr 07, 2012 | Tablets & eReaders
Lg ally touch screen stopped working
Likely a defective touchscreen, may be software related.
1. Remove Battery, Attempt to Restart phone. repeat at least twice.
2. Perform a hard/factory reset. a. for most phones the go into your phones setting and look for a reset option. b. Follow the prompt to reset your phone to factory settings. c. Make sure to back up all your data
3. Contact a service representative of your carrier or take the device into your carriers store, most of the time they will recommend doing a hard reset as shown above, they will NOT replace a device without doing a factory reset on the phone.
all goes well they'll likely replace your handset,
Jun 16, 2011 | Cell Phones
"Not allowed to dial" new c5000 wi-fi phone
Guys I had the same problem with the k599 Sciphone and none of the solutions found on the internet helped me. New chinese models tend to restart after testing is over and this results in turning the wifi application on. So I spent many hours on thinking how to bypass this function and this morning I woke up with an idea that really worked!! The steps are quite similar with the ones followed to debug older models:
put 2 chips on cell
Disable WLAN.
1-enter in factory mode *#3646633#
2-go to RF Test Tool
3-choose GSM, confirm OK!
4-go to Power scan
5-Select Band DCS1800 click OK
6-the cell frozen
7-wait for 3 minutes testing
8-while testing connect to a pc using the USB cable (do NOT select ANY of the options appearing on the cell screen)
9-Click the CENTER button of the cell until you go back to principal menu
10-go to settings/network settings and choose GSM Preferred or any other option (except WLAN only!!)
In this way the cell does not reboot, and the wifi application stays off, so the option can now be changed...
Hope this helps!
Greetings from Greece!
e-mail me to akiss_bd@hotmail.com if any questions..
Sep 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Touchscreen not working
You may be able to go the TomTom website and download the last update programming. If the problem is software this should fix it.
Jun 22, 2009 | Tomtom ONE 3rd Edition GPS
Map update notice screen
HOLD THE ON OFF SWITCH DOWN AND youPRESS RESET This should reset it back for t
Jun 20, 2009 | Garmin StreetPilot C330 GPS Receiver
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Pozz
please re-post the question in english because unfortunately i don't understand exactly the nature of the problem.
From what i get, i think you have a problem with the touchscreen allignment wich seems to be out of phase. This is mostly a hardware problem between the touchscreen controller and the motherboad. Also, a touchscreen has a finite life span and will loose accuracy over time and fail completely in the end. You should try a hard reset for your dell, (this will erase all the data stored on it and replace it with factory defaults). If this doesn't work, most probably the only way to save the device would be to have the touchscreen or lcd-touchscreen unit replaced in a service center.
Hope it helps.
Jun 07, 2008 | Dell Axim X30 Pocket PC
Touchscreen stopped working
Some where else in this site it said to hold the menu and map button while powering it on. I did that and it fixed my touchscreen problem, however I did loose all data, but I have that saved on my PC.
Sep 19, 2006 | Garmin StreetPilot 2720 GPS Receiver
Dual Electronics CECT P168 Cellular Phone Logo
313 people viewed this question
Top Dual Cell Phones Experts
kayceaz
Level 1 Expert
Tin Tin
B.Th. Pluijm
B.Th. Pluijm
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
