Wireless connection limited - How to repair when repair fails?
When I look at properties there is nothing in the default gateway, DSN server, or WINS server?
  • 8 more comments
  • Fish in FL Jan 20, 2008
    Yes Wireess G Router!
    I was signaled "limited or no connectivity" -When I went to check the connection status - details window shows the following:
    Property/value
    Physical address/00-14-A5-A3-C9-B1
    IP Address/169.254.12.39
    Subnet mask/255.255.0.0
    Default gateway/nothing
    DNS server/nothing
    WINS server/nothing
    When I close that window and select repair
    the repair option failed saying to contact network administrator? Guidence Please
    From command prompt -
    Wireless Network Connection 2
    IP Address 169.254.12.39
    Subnet mask 255.255.0.0
    Default gateway nothing
    Local Area Connection
    IP Address 192.168.2.2
    Subnet mask 255.255.255.0
    Default gateway 192.168.2.1
    Powered router down waited 40 seconds, powered up still limited connectivity - repair still failing unable to renew ip address
    how/where do I set default gateway? what is difference between router ip and wireless (sorry this is new teritory - still learning)
    When I look at bottom right of screen there is a monior icon with a "warning sign" this brings me to a status window where repair fails.
    How do I run setup on router or find dns settngs? When I type in address bar 169.254.12.39 it did not find any document matches?
    Yes - at another location. My brother came to visit... god knows what happened but I got home t lmited connectivity... I had to plug in to LAN connection. I moved to new location with same provider and they would not look at my wirless issue. Can't I reinstall using the wizard? How do I get the required information before I start?
    Connected now via cable to hub in router connected to modem box from Comcast
    Exactly what information do I need to get from Comcast so I can reinstall from scratch? Is this hat I should do? What are the steps so I can do this?
    Are you working tomorrow - it is late and this is when I make mistakes - Can we continue later? I will get with Comcast and reinstall in the morning...God willing this will fix the problem and I will be able to report back with good news.
    Phone line NO! I don't have a landline available in th new location. Can't I use the cable connection?
  • Computers & ... Master
  • 1,113 Answers
Please clarify what properties you are looking at, are we speaking of a wireless router connection?
Posted on Jan 20, 2008
  • 25 more comments
  • Soulvisitor
    Soulvisitor Jan 20, 2008
    At a dos prompt type ipconfig to see the ip of you pc
    ie
    so router hub needs to have same default gateway, and subnet mask of pc, and the ip need to be the same except last digit needs to be unique.
  • Soulvisitor
    my router properties pic
  • Soulvisitor
    Reboot router (power off, pause power on) sounds like you lost connection to internet provider.
  • Soulvisitor
    That looks fine wireless and router are within range, other one is just when you connect via cable, Reboot the router, you have lost connection to your provider, check lights on router, namely the adsl connection.
  • Soulvisitor
    DNS and default gateway are settings that are set by your provider they should be as they specify
    ie mine is (yours will not be the same)
  • Soulvisitor
    I'm speaking of rounters dns and Default gateway...
  • Soulvisitor
    You can set your default gateway on wireless to 169.254.12.1
    Routers ip and wireless ip should not have same last digit ie one should be 169.254.12.39 and the other as a eg 169.254.12.66
  • Soulvisitor
    failing unable to renew ip address on what and how are you trying?
    Run setup on router, you will need to know the dns settings given via provider, can you type router ip in explorer address bar and see home page of router?
  • Soulvisitor
    .39 is your computer's wireless ip not routers
  • Soulvisitor
    was this router running before wirelessly ok?
  • Soulvisitor
    Routers come with software to set up, normally this is done by connecting using network cable and running the setup program
  • Soulvisitor
    how are you on the net?
  • Soulvisitor
    Your internet provider gives you the dns settings when account is set up
  • Soulvisitor
    What started your problem
  • Soulvisitor
    I see brother is problem... anyway yes use wizard, settings needed are given by provider.
  • Soulvisitor
    This is what provider gives
  • Soulvisitor
    Will be on comcast web, or ring them, they would of given details via a email when you set up account.
  • Soulvisitor
    Hook up wireless g to phone line with filter provided
    hook up pc to wireless g via network cable
    run wizard
    it should self install
  • Soulvisitor
    once you have connection via cable and it works
    remove cable and run windows set up wireless connection wizard
  • Soulvisitor
    I'm in Australia and it is now 4:14pm on sunday, yes work tommorrow but am on line every night,
  • Soulvisitor
    Are you not using adsl
  • Soulvisitor
    Cable will be fine
  • Soulvisitor
    Sleep well til tommorrow
    for tomorrow...
    if at present you are connect via lan to the wirelss g, then all you should need to do is run the wireless wizard in control panel to establish wireless connection to router.
    cheers
  • Soulvisitor
    see LINK
  • Soulvisitor
    While you've been asleep I've been studying your problem, I think you wireless adaptor is out of range of you router.
    It looks like your routers ip range is 192.168.2.??
    and your adaptor is 169.254.12.39
    also the subnet mask is wrong ie the router is 255.255.255.0
    but adaptop is 255.255.0.0
    so we need to change it, I normally set mine for auto configue so I would suggeset you do that.
    To change the adopters IP settings go to control panel and network settings, right click on wireless adaptor and select properties, go down to internet protocol and select properties change to auto configure or set the ip as 192.168.2.22, subnet as 255.255.255.0 and default gateway as 192.168.2.1.
    save and reboot pc
    pics from mine
  • Soulvisitor
    no need to reconfigue router the dns settings in that must ok other wise you would have no net access when hooked in via lan
    I not sure of routers ip but I know it must be 192.168.2.something from looking at your lan settings
    to confirm what it is you can type in address bar of browzer 192.168.2.1 and you should get router page.
    Try above suggestions from while you were asleep before resetting router or contacting comset crew.
    hope this sorts you, if not post back
  • Soulvisitor
    Soulvisitor Jan 21, 2008
    wireless g default ip is 192.168.2.1 so your wireless tcp setting should be 192.168.2.whatever, but not 1.
    Gateway 192.168.2.1
    Subnet 255.255.255.0
    OK?
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Tip
Why can't you connect to the Internet?
First check your TCP/IP address - see my earlier tip on checking you are connected to a network. For most recent systems, (not Linux) open a command prompt window (type "cmd" in the RUN window from the start menu) and type ipconfig /all
you should see your network adapter name and IP address, a subnet mask (don't worry) and a default gateway, also a DNS server IP address. If ANY of these are missing, that's your problem, try repairing or resetting the network adapter. WRITE THEM DOWN. You may have more than one adapter, you need to identify which one is used for the Internet connection.
If they are all there, from the SAME window type "ping" followed by the IP address of your default gateway. If this fails, you have no connection to your internet router, find out why!
If this succeeds, type "ping" again, followed by the IP address of your DNS server. If this fails, type "tracert" and then the IP address of your DNS server. The FIRST address that will be reported is your default gateway; followed by your ISP address; if the only address you see is your default gateway, the link to your ISP  is down, give them  a call. If it succeeds, from the same window type "nslookup"
You will see a chevron prompt, type in the name of the site you want to go to, e.g google.com.
You should then see a reply from your DNS server, and an IP address for your required server. If not, then either your DNS server settings are wrong OR the server does not exist. It will be obvious which it is from the reply you receive. If the DNS settings are wrong, you can change them from the Control Panel, Network, Network adapter, Properties, TCP/IP v4 properties menu; try setting DNS server to 8.8.8.8 or 8.8.4.4 and try again.
on Mar 26, 2010 | Computers & Internet
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
Hello :), One day I turned on my computer and my network connection shows up limited connectivity now every time I turn on my computer it my internet connection shows up limited connectivity. I've tried...
if you are getting limited connectivity.. double click on network icon on task bar and go to support tab and click on repair..it will work.. if its not working give the ip and dns and default gateway manually.. not DHCP
Dec 31, 2009 | Microsoft Windows? Vista Home Premium...
My 2Wire Wireless adapter connection keeps getting disconnected every 5-10 minutes(ATT U-Verse Internet Svc)Is there a better adapter to resolve my problem ? Thank you.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Computers & Internet
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
Limited or no connectivity
hi,
welcome sir,
what i can suggest u is that just reset the router and then install the wireless driver into ur computer and then try and connect to wireless network and hope u will be connected......good luck....
pls rate this solution..........pls...thanks
Feb 12, 2009 | Adapters.com PLANET USB WLAN...
I am attempting to connect my laptop to the internet using a wireless router. The Acer eNet Management displays that I have an excellent connection at 93 percent, but I am still unable to reach the...
Ok. Is this a new laptop or router? I suggest you restart your internet modem, then your router and then your laptop. In that order. Letting each come online before starting the next. Then, you need to bring up your control panel screen. In that click on Network connections and look for the Connections tab. Click repair. Or if you have the internet icon in your system tray, bottom right by the clock, then right click it and choose repair. Hope this helps.
Jan 11, 2009 | Acer Aspire 4720 Notebook
Wireless router problems
your computer is only connected to the signal coming from the router that's why it's saying connected but it seems that your router is not properly configured to provide internet access since your dns server is the same as your default gaetway. it could be that the your router is not in sync with the modem.
- if it's working before, tyr to power cycle everything by turning all the devices off then turn on the modem first, wait for all the lights on the modem to turn on then power on the router and the computer.
- if the router is for initial setup, kindly provide me you ISP, brand and model of the modem and how you connect the modem to the router and tell me if how you access the internet directly from the modem.
Jul 02, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Cannot connect to the internet via the Wireless router.
contact ur service priovider they will provide u  ur ip address and default gateway as well as dns server address
After getting ur ip
go to network connection > wireless network connection > properties > scroll down for internet protocol  and double click on it > click on use  the following ip and then enter the ip address and default gateway with dsn server provided  by ur service provider > click ok
now u  r done and u can connect 2 the wireless network
Mar 01, 2008 | D-Link DSL-G604T Wireless Router
Computers & Internet Logo
528 people viewed this question
David Payne
David Payne
