Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos LC 37D43U
Even with the volume at its max. we cannot hear the t.v well enough.No home theatre or anything special.It is hooked up with bell sattelite and nothing else.Please help.
  • lherle Jan 22, 2008
    thanks for your prompt response.
  • 86 Answers
If you have satellite, I am assuming you at least have a converter box hooked up. If so, make sure the converter box volume is set at its max. There may even be a volume setting in the converter menu that forces the volume output of the box to always be at full so that you don't get variations in audio when changing channels. Warning...before attempting this, please turn down the volume on your tv to at least the middle setting so you don't blow your tv speakers if this works.
Posted on Jan 20, 2008
6ya staff
SOURCE:
I have a Sharp Aquos LC-37d43u and when I turn the power on the picture and input show up for a second then the whole screen goes black. Any thoughts?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 23, 2015 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
What is the size of the 4 mounting bolts on the Sharp Aquos LC-37D43U?
To know more about this, you have to download its repair manual. Its disassemble section will have all details.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Sep 16, 2014 | Sharp AQUOS LC-37D43U 37" LCD TV...
I need Aquos LC-37D43U firmware
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 04, 2014 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Hi i have a sharp aquos lc-37d43u tv and I can't get it to connect to my computer .I tried HDMI and VGA but I just don't seems to understand how to make it work ;( Please HELP
prob with sansui sty 0330 LCD TV
hi,i have a sansui sty 0330 tv and the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Dec 18, 2013 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
My LC-37d43U won't turn on, no lights, no nothing...?
Open fuse on power supply board, or the power supply is dead, or there is no voltage coming out of the receptical out of the wall, You can hget a new power supply at b www.partstore.com take care.
Nov 03, 2011 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
My sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
May 24, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
My sharp aquos television sound is very low even on max.
I had this problem with my Charter and the box had a sound button on the actual box, not the remotes. Now I have switched to Direct TV Box and have found while not so low I can't hear it, it is much lower than I know it can be and have to turn it up in the higher numbers or turn on the surround sound to hear it. Anyone know what to do with Direct Box, Direct didn't know.
Sep 05, 2009 | Sharp LC-26D4U 26 in. LCD Television
Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
Apr 10, 2009 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Can you hook something up to the aquos to get louder volume?
ARE YOU HOOKED UP TO A CABLE BOX? IF SO THERE IS A VOLUME ADJUSTMENT ON THE CABLE BOX TO HELP OUT. IF NOT I'M AFRAID YOUR ONLY SOLUTION IS TO HOOK UP A SURROUND SOUND SYSTEM.
Feb 03, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
253 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
