Question about Pitney Bowes Office Equipment & Supplies
There is a pending job stuck in my Pitney Bowes 2050 fax machine queue. Someone forgot to dial a 9 before the number in order to reach an outside line. I can't delete the job, nor edit it, and it's jamming up our faxes! Help!
  • 3 more comments
  • asunkissed8 Dec 14, 2009
    I have tried that, but when I go in to even try and edit the job, anything that I touch on the screen just beeps at me, it will not actually allow me to go in and edit anything. At one point, we were able to send a fax out, and I went in to edit THAT job and it let me change the location, but this one job is just stuck in there and won't let me change it at all! Even our service desk said they had no solutions
  • asunkissed8 Dec 21, 2009
    I thought either one of those would work, but...
    The machine will not allow me to enter any dashes (-). It just beeps at me!
    The reboot did not work, the job is still there :P
    I thought either one of these would work, but..
    my machine won't allow me to type the dashes -
    and, the reboot didn't clear the job :P
  • asunkissed8 Dec 23, 2009
    For some reason my comments keep disappearing.. The machine won't allow me to type the dashes (-), and I tried to do the reset, but the job is still listed in there!
  • asunkissed8 Mar 18, 2010
    I hope you read this Art! Out of pure frustration, I printed out your solution again today and tried to get into the service menu, and for some reason, it WORKED this time!! I was able to delete the job.. thank you soooooo much! I was going crazy :)
  • 149 Answers
Press yhe edit Jobs key on screen, select job and press stop, or press edit and add 9
Posted on Dec 13, 2009
Testimonial: "This would be a great solution if our fax machine would allow us to edit anything :P"
  • Nike Merritt Dec 21, 2009
    1. Press the System Setup TAB
    2. Press the Options BUTTON
    3. Press the Access Control BUTTON
    This display appears.
    4. Press the C/CE KEY on the Operator Panel to delete the 2050 Access Code.
    5. Enter ∗, ∗, ∗, 1
    Enter 095 job clear
    if you cannot get to service mode, try this with a straightened paper clip:
    If the machine is locked up (ie. Printing) and you cannot access the
    service mode, you can perform a Job Clear by engaging the reset switch
    on the NCU. First turn off power. Next, insert a small screw driver
    through the tiny access hole on the left side of the machine just above the
    line cord connector. With the switch engaged, turn on power
    simultaneously. The unit will reboot. Release the the switch.
  • Nike Merritt Jan 15, 2010
    sorry those are not dashes those are stars or asterisks. lost in translation to website ***1
Pitney bowes 9820 fax machine is popping up error 50 check printer what might be the problem
Error 50 is a service error and you will need to contact your local computer repair or go to their site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes 1530 Memory Full
1. Press FEATURE
2. Press 9 9
3. Press * * * 1 (this is the service passcode)
4. PressYES
press 095
press yes
press stop to exit
Sep 16, 2009 | Office Equipment & Supplies
Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Aug 20, 2009 | Pitney Bowes Office Equipment & Supplies
We have a model 9930 fax machine the power went out,and i everything reprogrammed for speed dial, but it asks for access code everytime,how do I stop that
Function 9, yes, access code is 9930, yes, press no until you get get to set access code, press yess. Press no to clear code, then press yes. press stop
Jul 08, 2009 | Pitney Bowes 9920 Plain Paper Fax
I have a paper jam on my Pitney Bowes 1630. The
Good Luck, When the paper is stuck in the back, it is in the fuser and you may be able to get the paper out, but probably the drive for the fuser is messed up, which caused the jam in the 1st place, if you get the paper out, the next one through will probably jam up again. Technicians usually just replace the fuser. Oce is the repair entity for these machines now. 1 800 2423 5556
Jun 09, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
Jan 31, 2009 | Pitney Bowes Office Equipment & Supplies
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
353 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
