Question about Olevia LT42HVi 42 in. LCD Television
Need to shift from cable mode to antennae mode
We called the company. Than you.
Posted on Dec 12, 2009
When in antenna mode why does it freeze then turn off and come back on in HDMI1 mode?
[PDF]USER MANUAL - Vizio
www.vizio.com/documents/downloads/hdtv/.../UM_E550iB2.pdf
VizioAny other voltage than the specified voltage may .... Do not locate the antenna near overhead light or power circuits, ..... the instructions that came with your mount. ...WIDE. Switch the display mode. MUTE. Turn the audio off or on. BACK ..... Zoom. Normal. Note: Aspect ratio settings may vary by Input source. HDMI-1. HDMI- ...
[PDF]USER MANUAL - VIZIO
cdn.vizio.com/documents/e40c2/um-e40c2.pdf
setting and this is the setting in which power savings will be .... electric shock, do not perform any servicing other than ... connected to the TV, make sure that the antenna or cable system .... Locking and Unlocking the Custom Picture Modes ..... ...... .....BACK. Go to the previous on-screen menu. MUTE. Turn the audio off or on.Missing: freezes
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Jan 21, 2016 | Vizio E420VA 42 in. LCD HDTV
Trying to convert from cable to antenna...I get no signal and it seemingly goes into sleep mode
Consult your TV's owner manual and enter "set up mode" to switch the RF or Antenna input from: CATV / Cable to: Antenna / Off Air. Then, allow the TV to scan VHF & UHF for signals strong enough to "tune in". You may need to upgrade your antenna in order to collect enough signal to display video properly. Make sure that your TV has a digital tuner (ATSC) as the old analog tuners (NTSC) have no signal to tune since broadcasters were forced to digital transmitters by the FCC years ago.
Use the site linked below to help you select an antenna that will allow you to receive all signals possible at your location - without buying more antenna than you need.
Like AntennaWeb org
Apr 08, 2015 | Televison & Video
How do I shift the radio antenna off the roof of my Mazda BT50 onto the bullbar?
remove the roof antenna ( unscrew off the mount) buy an aerial for the bumper. run the coaxial cable back to the radio and pull the existing cable out and after fitting a connector on to the end of the new cable plug it into the back of the radio. It will be a lot of trouble to remove the existing cable and roof mount and you will need it at a later date.
Mar 11, 2014 | Mazda Cars & Trucks
Antenna unrecognized.
Sometimes the TV will lock out other inputs when a cable is connected. Try the antenna by itself and put the TV in Channel scan mode. If this works reconnect the cable TV cable. If that doesn't work you may need an A/B switch
Feb 19, 2018 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
Moved, no longer have cable and not getting any channels via attenna. Is it just bad reception or do I need a digital converter because of the change to digital stations?
Could be bad reception and or make sure the tv which was in the cable mode when you had cable now needs to be in air or antenna mode. IF you have another tv that works ok then you will know the channels just need to be reprogrammed for over the air signal. Go into the menu of tv and find program channels and switch to air or it might say antenna..
Oct 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
I plugged antenna in but I still can't install channels problem is that I cant choose "channels installation" option maybe because tv is on video mode but I can get it to normal mode...
Antenna?? If you connected an antenna to the TV, you can only picking up radio waves. In the TV's menu options you should have a connection selection to choose from "Cable" or "Air". With an antenna, Air needs to be selected. Go through your "Input" selector from tv remote and select "TV" which is always the first selection. If this does not help, let us know exactly what is connected to the tv whether it be a COAX cable alone, a coax connected to an antenna, or if you have rabbit ears connected.
Jun 30, 2010 | Televison & Video
Broken antenna - 1996 oldsmoblie ciera
I assume it is an extendable antenna, if so loosen the ring around the antenna base there are usually like 4 slots on it, after you have removed the ring, have some one turn your car to the accessory mode and turn the radio on, your antenna or what is left should come right out, to install your new one just feed cable down hole and have them turn your radio off you may need to spin the antenna just a touch to let it catch cable, be sure to put your antenna ring back on.
May 27, 2009 | 1996 Oldsmobile Cutlass Ciera
The TV somehow moved to Antenna - we need it on cable but can't figure out how to do this. It is a Vizio VO22L HDTV10A
Hit orange button in middle of remote: Menu comes up. Hit left arrow three times and you should see a menu with tuner mode at top. Hit down arrow to highlight tuner mode, use right or left arrow to select antenna or cable. Hit last button until menu disappears.
You're welcome.
D,J, Rigney
Dec 16, 2008 | Televison & Video
No uhf with antannae
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Stargazer
Mar 21, 2008 | Orion STV2763 27" TV
Olevia LT42HVi 42 in. LCD Television Logo
41 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
