Question about Dell Dimension™ B110 PC Desktop
I recently installed a new larger, hard drive, but numerous problems have developed with it. Can I reinstall the old hard drive and pick up where I left off?
  • 154 Answers
When you install a new hard drive you need to install also a software to make your drive working. The new install hard drive does now contain a copy of windows software.
Posted on Dec 10, 2009
We have paper jump problem.after reseting and changing powder developer.for konic Minolta .bizhub250 bw
So you recently replace the drum? and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 21, 2016 | Minolta Office Equipment & Supplies
Laptop won't boot. Caps lock and numeric lock lights are blinking. It was working fine after I installed a new hard disk and restored the whole system using my recovery disks and backup. I installed...
Don't restore the system to a hard disk of different size. You may fix the old disk again and use it while using the new (probably larger) disk as an external disk (by fixing a driver bay).
If you want to use the new disk you will have to install the operating system and software from scratch.
Jul 27, 2011 | HP Pavilion dv5-1004nr Notebook
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Cannot get Toshiba P@% S507 to see new hard drive.
you can't use a restore disk made for a specific hard drive with a much larger hard drive. This information is checked by the restore cd. You would need to contact toshiba and get a regular windows install cd.
Apr 01, 2009 | Toshiba Satellite P25-S507 Notebook
Looking to upgrade hard drive
Pretty much just how big of one does he want.
Jan 07, 2009 | ASUS NVIDIA nForce Chipset A7N266-VM...
LAPTOP HARD DRIVE UPGRADE
Get adapter here: http://www.geeks.com/details.asp?invtid=2020. Download hard drive cloning software. Connect new drive to adapter, and USB cable to booted notebook. Follow cloning software instructions. When finished, swap out the old hard drive.
Apr 11, 2008 | Averatec 3200 Notebook
2nd HDD installed as slave but still unloaded with software
Simple, if your hardware is working all OK do this:
AND DO THIS CUZ WINDOWS XP HOME EDITION lacks of the needed administrative tools.
Go to the net and find PARTITION MAGIG or PARTITION MANAGER... download the windows version of any of those and partition the HD with them.
REMEMBER:
1. PARTITION MUST BE LOGICAL, NOT PRIMARY
2. PARTITION MUST BE NTFS (Windows XP version) that you will see in Partition Magic options...
3. If you format from Windows, disk must be intitialized as BASIC type.
if you do this and you suceed the HD will work, if not, it has a problem, either logical or physic.
Good Luck
Mar 10, 2008 | Maxtor Hard Drive
Hard Drive Installation
First you need to transfer all your files to disk cd or other. Then find out where the hard drive is. In that model I think its on the side unscrew the screws and it should slip out by pulling on it. then swap it over. When you turn it on depending where you got the hard drive it may need to reinstall windows if it dont boot up. The bios should pick up your new device/drive.
Sep 29, 2007 | IBM ThinkPad T23 2647 Notebook
Dell Dimension™ B110 PC Desktop Logo
108 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
