Question about GE 30" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel
Oven burns food ,can not set properly , where is the senser for oven.
  • 6,784 Answers
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Posted on Dec 10, 2009
Oven burning food
Get an oven thermometer and measure the temperature in the oven to determine if it is at the correct temp or not. If not then there is an oven problem possibly the oven temp probe or the oven electronic controller. If the temp is correct then you are doing something wrong as a cook such as oven temp set too high or cooking for too long.
Nov 19, 2013 | Hotpoint Kitchen Ranges
Electrolux EOD 985 bottom oven over heats burnng food
thats because the heat sensor isnt working properly need to replace
Apr 25, 2012 | Ovens
Oven won't brown food properly
sounds like the upper element is burnt or the fuse is burnt.check the fuses first,by opening the access panel at the top and rear of the range,check the fuses to verify that they are good,if okay then open the oven door and remove the element and inspect the contacts and element for burn marks or breaks.if so replace either the element or the burnt contacts.
Nov 21, 2011 | Kitchen Ranges
My new oven doesnot cook lasagna through evenly.
Hi Angela,
There are many different possibilities that can cause this issue. From a faulty thermostat, to placement of the food in the oven, or not giving the oven enough time to pre-heat before placing your food item in the oven to be cooked. I have found that on many ovens they can reach well over 450 degrees during the pre-heating cycle. I had a customer who called because her new oven was burning her brownies on the outside and they were not done on the inside. The customer told me that she would wait for the pre-heat signal beep(oven is ready) before putting the tray of brownies in the oven. When I initially checked the oven tempature using a fluke meter and a thermocouple at the center of the oven I found that the oven was close to 460 degrees when the beep went on to indicate the oven is ready! So that is why she was burning her brownies. It took another 10 minutes after that for the oven to stabalize and keep the tempature at 350. So you might want to give your oven 20 or 30 minutes of pre-heating time before you put your tray of Lasagna in the oven. Always make sure to place the food item at the center most part of the oven. And if you are cooking several trays make sure to stagger their position on each rack so they are not right above/below each other. The positioning is important because it can interrupt the natural flow of heat in the oven. So if you let it pre-heat for a half hour and are still having the burning issue then you should have the oven tested for proper calibration to make sure the thermostat is working properly.
Mar 10, 2010 | Garland H283 Gas Kitchen Range
Large oven burning food on top shelf when in fan assisted mode
Always cook food in the middle of the oven. Assuming this is an electric oven, there is a heating element up there that will cause burning of food, much like a broiler works.
If you must cook that high up in the oven, then cover the food your cooking with foil.
Dec 16, 2009 | Kenmore Ovens
Sparks in oven
the burning is normally caused by a small particle of food getting stuck on the waveguide cover, this then carbonises and starts to arc. replacing cover should return oven to normal
Feb 22, 2009 | Sharp R-1480 Microwave Oven
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
The oven is constantly burning things I cook. If I reduce the heat - food doesn't cook properly and when you use the correct heat, the bottom on the food is burnt black. Can anyone help. Also no way of...
There are other possibilities, but,..... this sounds like what will happen if you use too large of a pan or cookie sheet(s) in your oven. If there is not much space on the sides and front and back of the pans, the heat gets trapped under the pan (causing burning) because not enough hot air is getting to the top of the oven where the oven thermostat is located.
Sep 23, 2008 | Kitchen Ranges
Concealed oven
consealed bake means that the bake element on the bottom had a metal plate above it to make it easier to clean and to allow you to use the lower racks without burning the bottom of your food. To use, you want to make sure that the oven temperature that you set has been reached before putting in your food to be cooked. You also should put the racks one notch lower than you normally would. If you do this, you should have no problems with your food cooking unevenly.
Jun 28, 2007 | Amana AOCS3040SS Electric Single Oven
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
GE 30" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel Logo
117 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
