Question about Maytag Performa PAV2200
Bolt broke on agitator the top portion of agitator where the softner goes wobbled I tried to tighten up and snapped the bolt. If I can extract the bolt can I purchase a replacement bolt? It looks like it was a fibre and metal washer on it that was worn
  • 128 Answers
Get a bolt remover called grabbit then do a removal then replace bolt ...
Posted on Dec 10, 2009
How to add fabric softner to the agitator
Does it have a small hole in the top of the agitator on the flat spot? if so then this is where you pour the softener.
Dec 23, 2012 | Washing Machines
How to remove agitator
Remove the dispenser and then the bolt below. Then grab the agitator and yank it out. Separate the 2 pieces by placing the agitator on the floor. Hold down the base with your feet and yank the top portion off there. then you can replace them worn out dogs.
I like to hold the bolt and slip the cam upside down into the upper portion and then line it up with the base and snap the 2 together.
Video how to
Nov 09, 2011 | Estate TAWS800JQ Top Load Washer
The agitar isn;t working right. Is there
The part you need is FSP# 80040 dog kit goes inside the upper agitator. installing them dawgs: You sit the agitator on the floor, put you feet on the base and snatch the top portion off of the bottom. You put all the dogs back in the cam set them up into the upper portion with a piece of pvc pipe or equivilent and invert onto the base, lining up the tabs on the bottom with the holes in the upper portion being careful not to smash the tabs on the base that hold the upper portion onto the agitator. Snap it all into place and gently re-install it being careful not to over tighten the nut. Watch this video:
Jun 06, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
Mover agitator slips
The agitator bolt may be loose, or the dogs may need replaced. The following link explains how to access and repair:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can view what agitator dogs look like at appliancepartspros.com. Just type in your model number and look for item 18 under the Agitator, Basket and Tub heading. A replacement kit only costs about $5. For a bit more, you can purchase the entire agitator repair kit for about $11 (item 22). The exploded view diagram can also assist you.
Your agitator has a cap that comes off the center post, followed by an air gap cap inside. The air gap cap just pulls out, exposing the agitator bolt. The upper portion of the agitator (called the "auger") will lift off once the bolt is removed.
NOTE: Make sure when you reassemble the agitator that you remember to reinsert the air gap cap and that the rubber o-ring gasket is intact. Without it, water will eventually work into the gearcase (transmission). Also make sure you do not overtighten the agitator bolt. Doing so may damage the agitator or restrict its movement. Tighten until snug.
If you have any questions, please let me know. I hope this helps you.
Jul 21, 2009 | Whirlpool WFW8300SW
Agitator dogs stipped
the way to do this depends on if it is a dual action or triple action agitatior.
dual action
- Remove fabric softner dispenser
-pull off plastic cap with flat blade screwdriver
- bolt is under plastic cap 7/16"
triple action (bounces up and down)
remove fabric softenr and plastic cap
with a 1/2" drive socket extention, put into square hole and unscrew spring assembly. once unscrewed top portion of agitator will come off
May 27, 2009 | Washing Machines
Adgitator removal
Just follow these steps:
1. Remove the center dispenser from the top of the agitator. It should just pop off.
2. Locate the white plastic cap underneath and pull straight up to remove.
3. Locate the agitator bolt underneath and remove using a socket and ratchet (can't remember the size). Hold the agitator still with one hand in order to loosen the bolt.
4. With the bolt removed, grasp the agitator by the bottom flanges and pull straight up. It should lift off the center post.
NOTE: Sometimes these agitators will stick due to years of detergent accumulation. You may have to wobble it back and forth to get it loose.
If you have questions, please let me know. I hope this helps you.
May 03, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Overheating
Ouch! Was it from over-tightening or trying to remove the bolt?
Really, I need more information...
Regardless, you'll have to take the thermostat housing off and remove that broken portion of the bolt. The reason I asked if it was from overtightening, it should be a little easier since the threads aren't locked-up, to remove the bolt section. Hopefully there's enough bolt shank sticking up to lock some vice-grips to.
If the bolt broke trying to loosen it, you may have to drill into the broken bolt remnant and use an "Easy-out" to extract it.
I know... big pain. You can do it. Hey, stuff happens. Good luck!
Apr 25, 2009 | 1993 Saturn SC2
How to remove the agitator
do you see a bolt? if you do you just need a long extention, socket and ratchet, if not the agitator justs pops off. grab it from the outside edge at the base (bottom) on both sides and **** up, the older ones are alittle harder to get off but they will come off just snaps on
Mar 07, 2009 | Washing Machines
Wobbly agitator
If you remove the center cap from the agitator there should be either a bolt or a square recessed socket that you can attempt to tighten. The bolt is either 7/16" or 1/2". The recessed socket can be tightened using a 3/8" to 1/2" socket adapter.
Make sure the agitator is seated properly on the center post. You can accomplish this by finding the mounting bolt and loosening it enough to free the agitator on the post and push down evenly on the bottom flanges at the base of the agitator where it meets to bottom of the tub.
Try this and let me know if it helps. Post back if you need further assistance.
Feb 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
