Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Printer won't print. Flashing lights under ink symbols and E. Have unplugged several times, taken ink cartridges out and put back in. Any suggestions?
    Problem Solver:
  • 19 Answers
Have you tried to possibly replace the cartridges one at a time till you find the problem one.. or perhaps its the contacts on the cartridge that need to be cleaned.
Posted on Dec 10, 2009
Flashing light opposite ink symbol
Indicating cartridge faulty/exhausted, replace the cartridge..
Oct 11, 2011 | HP DeskJet F380 All-In-One Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Full cartridges = empty :S
Solution 1
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
* Remove the tank.
* Connect a hose directly on the inlet ink.
* Locate the sensor of reservoir and press it to make as if a cartridge is available.
* Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
* Replace the tank up and do a test print.
* Repeat the procedure several times if the nozzles are clogged.
Solution 2
Using a syringe and some alcohol to unblock the holes can also be very effective.
* Step 1: Remove the cartridge from the computer
* Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
* Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
* Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
* Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Jan 02, 2010 | Epson Stylus 880 InkJet Color Printer
Printer won't print error message remove and check right cartridg
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Sep 16, 2009 | HP Officejet 7210 All-In-One InkJet...
Nothing will print; blinking amber light
Are you out of ink? when you open the lid to the printer while it is turned on look at were your ink cartridge stops and that will tell you if you are out of colour or black ink. Which light is blinking the one on top of the paper symbol or the one on top of the ink symbol. It may be that your cartridge either black or white just need to be taken out and put back in I found that if I wiped the bottom of the ink cartridge where sometimes you get build up that it would work again or give it a shake but make sure you cover up the bottom were the ink comes out before you shake it. Hope this helps!
Nov 15, 2008 | HP DeskJet 920c InkJet Printer
Wrong Cartridge
replace print head. print head is bad.
Jul 27, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Catridge won't go to right position
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Jun 12, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Changing the ink cartridge in Epson Stylus CX4200
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
May 15, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Dell 964
i suggest yo contact dell, they may be able to send you some ink cartridges for testing or you could purchase some new ink (if the new inks doesnt work then its a hardware issue)
Feb 22, 2008 | Dell Photo 964 All-In-One InkJet Printer
Ink and paper lights flashing red and I cannot print
No body wants to take it to repairs, we all hate spending money if it can be avoideded. Do't fret. First, i would bet you have a paper jam that you have missed. This would stop the carriage and head cleaning. Open up the cover as if replacing ink. Get a torch and really thoroughly check for tiny paper jams or ujo's(unidentified jamming objects)check where paper goes too. Now close cover turn off, unplug, all cables, replug, turn on, try printing now. Post back if no good. Cheers lilacgerry
Aug 27, 2007 | Epson Stylus C84 InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
116 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
