Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Ink powder keeps pouring out of cartridge - Panasonic Panafax UF-585 Plain Paper Laser Fax
    President:
  • 3,085 Answers
It is defective, replace it.
Posted on Dec 10, 2009
HP 1010 12-A CARTRIDGE...
Hi
Replace the ink cartridge with another
Jan 14, 2014 | HP 12A Black Laser Toner Cartridge...
Hp 9500 Toner Powder
Depends up on the properties HP designed the TONER.. You can't refill the cartridge with another normal toner with this one, pl submit the cartridge to best re-filler or pour specified compatible toner needed to re-fill
Jan 30, 2012 | HP LaserJet 9500mfp Printer
I want to know what is inside the printer cartridge
The ink cartridge are of different type and contains ink in different form.
  • Thermal Ink jet Cartridge (HP, Canon) - The cartridge contains a liquid ink, which is heated by a heating plate on the cartridge. A bubble is formed which forces the ink which comes out of the nozzle.
  • Piezoelectric Cartridge (Epson) - The cartridge contains piezoelectric crystal, which when current is applied changes shape and size forcing ink out from the nozzle.
  • Toner (Laser Jet Printer) - A drum contains powdered ink (toner), which is spreads on the paper using negative and positive charges and the heater sticks the ink on the paper.
Regards,
Shrey
Jun 07, 2011 | Computers & Internet
Can we refill the ink toner of ricoh MP 1600 le
A laser printer does not use ink, it uses toner powder. This powder is very fine and it is not wise to breath in this powder. I suggest you either purchase a recharged toner cartridge or a new toner cartridge for your model laser printer.
Oct 23, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Printing is too light on deskjet 3845
Try the solution below :
Open the printer cover and remove the toner cartridge, one by one. Don't remove them all at once. Place one hand on each end of the cartridge and keeping the cartridge level(flat) with the floor, rock it back and forth (not end to end). This helps to distribute the ink powder inside so that it evenly contacts the drum.
Remove each color cartridge, rock it to distribute the powder, then keep it level while you re-insert it into the printer.
Hope this helps. Don't forget to rate my response.
Jul 22, 2010 | HP LaserJet 2605DTN Color Printer
How to refil konica minolta toner
Shop for the appropriate refill kit. When purchasing a refill kit, double-check to be sure that the toner in the kit is compatible with the toner required for your model of Konica Minolta printer.
  • Step 2 Empty the old printer cartridge. Be sure to completely empty the printer cartridge that you plan to refill. A compressed air can is ideal for this purpose and can be purchased online or at most office supply stores.
  • Step 3 Remove the plug. The cartridge plug may be covered by a colored end plate, depending upon the model of your Konica Minolta printer. Simply unscrew the end plate, and then remove the plug. If using a screwdriver to remove the plug, be careful not to puncture the plug, as this will cause the toner to leak out of the cartridge and into your printer.
  • Step 4 Refill the printer cartridge. Shaking the powder in the refill toner bottle before attempting to pour it into the cartridge will cause it to pour much more easily. Do not squeeze the bottle, but allow the toner to simply pour out. Replug the cartridge, and gently shake or rock it back and forth two or three times to evenly distribute the toner powder inside the cartridge.
  • Step 5 Check for leaks. Before returning the cartridge to the printer, check the outside of the cartridge for any powder particles that may have spilled or leaked during the refill process. Wipe the particles off the cartridge, and gently shake it once more to check again for leaks. If no powder particles appear, then it should be safe to return the cartridge to the printer.
  • Step 6 Return the cartridge to the printer. Once you have refilled the printer cartridge and have checked for leaks, you may now return it to the printer. Go to your printer properties/settings and select the option to indicate that a new printer cartridge has been installed. Print a sample page to check print quality
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    May 22, 2010 | Konica Minolta PagePro 1350W Laser Printer
    How to refill ink in it
    The printer doesn't use ink, it uses toner, a black powder. The toner is then pushed onto the page using magnetic force and fused to the paper using a laser. Which replaces the traditional "ink injection" method.
    The toner cartridge is a black unit that pulls out located behind the top access panel in the front. This unit contains a glass drum and behind it a well of toner powder. Usually you have to replace the entire unit.
    There are toner cartridges with plastic caps which can be removed and then refilled with the powder. However, this powder is messy, difficult to manage, and eventually the drum will become scratched and worn since it is not really designed for prolonged use. So I recommend just replacing it.
    While the toner cartridge will run more than ink. The frequency with which you have to replace it is significantly less. So while ink can run you as much as $0.25 a page when you factor in the wear and tear on the printer. Laser printers are more along the lines of $0.04 a page.
    If you replace the toner, read the directions carefully and be sure to remove the plastic shipping strip from the side of the cartridge. This strip is used to hold the toner in the cartridge while it ships and will keep it from working properly.
    May 12, 2010 | Canon LASER SHOT LBP-2900 Printer
    Dell 3110cn - getting grey tint and wavy lines
    It sounds like you have leaky toner or the imaging drum needs to be replaced.
    Feb 17, 2010 | Dell 3110cn Laser Printer
    The ink light on my printern is flashing. I
    open your cartridge door pour some hot water and then close it and then take an egg put chilly powder and salt on top of it and then garnish it with some onions. heat your printer. it will be alrite.
    Dec 12, 2009 | HP DeskJet 932c InkJet Printer
    Refill Toner Cartridge for Laser Printer
    Nobody has a clue how to refill a laser cartridge with ink. :)))
    OK< just kidding, here it is:
    First of all, laser-cartridges have toner (a fine black powder) and not ink.
    Second: There are 2 methods to refill a laser cartridge: dismounting it to get to the toner chamber (involves a lot of tehnical skill) or the melt-and-pour method (see here http://www.urefilltoner.co.uk/), but you need the melting device.
    But because from your question i see you dont know a thing about refilling, better go to a refill center.
    Feb 14, 2008 | HP LaserJet 1012 Printer
    Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
    26 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
