Question about HP PSC 950 All-In-One InkJet Printer
Printing Slow I pulled out a paper jam and now it prints very slow. I checked to see of it was set on "best" quality and it is still on "normal". None of the settings have changed
  • 96 Answers
Check for more paper caught around the rollers....
Posted on Feb 09, 2008
My canon MX882 printer has become VERY slow at printing pictures. Almost undo able
This all comes down to file size of the picture and the quality you are printing in. Check your printer settings and see if you are printing in least, normal or best quality. Also look at the actual size in pixels of the picture you are printing.
Feb 20, 2015 | Canon Office Equipment & Supplies
Why did my printing rate suddenly slow down to about 20 Why did my printing rate suddenly drop to about 20 % of normal
Check the print quality settings in the Printer Control Panel. If set to best and color it will slow printing considerably and use ink much quicker. Draft and B&W printing is usually fastest and sips ink compared to other modes.
Feb 20, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
Slow printing
Check that the default setting for print quality on your printer driver hasn't been set to "Fine".
In your Opertaing System, find your printer (in XP it's under Control Panel / Printers and Faxes) and select Properties. This should then bring up the settings for the driver.
Fine printing quality takes over double the time "Normal" quality takes so would considerably slow your printing.
Apr 10, 2014 | Brother MFC 210C All-In-One InkJet Printer
It takes a looong time for the printer to print just a few lines
What print quality are you using? Go to the print window, check properties. Under the features tab check print quality. If you are using anything above normal such as Best or Maximum DPI, more memory is necessary to print and will slow down printing. If you don't need high quality printing, change the setting.
Jul 27, 2010 | HP Photosmart C3180 All-In-One InkJet...
920c is printing very slow, like 1 copy in 5
it is possible that your printer settings is set print high quality for a photo paper. try to check if you are printing on plain paper, select paper type as plain paper and quality to normal.
Nov 06, 2009 | HP DeskJet 920c InkJet Printer
How do i clear a paper jam
The Lexmark Printer you are having a very sensitive printer.
Normally this tyoe of Printers are very very slow in Printing job.
Comparing with other laserjet used.
If the Laptop / Printer are under warranrty, the Service engineer
can rectifity the printer jamming.
Solutins :
Make the Printer - Monthly service compulsory.
Use only good quality paper in the Lexmark Printer.
Do not pull the paper through hand, when the print out is coming.
Regards
Jul 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printing is very, very slow
Issue The printer is printing slow. Solution Follow the instructions below to manually select the paper type and print speed.
  1. In the application you are printing from, click File , Print , and then Properties . The Printer Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Change the Print Quality from Automatic to the desired setting.
  4. Change the Type is selection from Automatic to the appropriate paper type that you are printing on.
  5. Click OK .
Mar 03, 2009 | HP - HP Photosmart 8250 printer
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP PSC 950 All-In-One InkJet Printer Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
