Question about Brother IntelliFax-2820 Laser Fax
Paper comes out folded & has started jamming - Brother IntelliFax-2820 Laser Fax
  • 1,297 Answers
Clean or chnage the fuser roller and the exit parts rollers.
Posted on Dec 12, 2009
Hp laserjet 3015 paperjam
Plz see if the corner of the paper will be folded or it has been folded earlier and now it is straight then also that paper will be jammed. So use new unfoiled paper.
While inserting it see it is straight in the tray.
Oct 26, 2012 | HP LaserJet 3015 All-In-One Printer
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
How do I clear a paper jam in a Samsung ML-2510. I turned printer off & on again. It goes through the motions of clearing, but no paper comes out. But when I print the paper folds up like something...
have you made sure that there is NO PAPER stuck in the paper path? even a small piece of paper can cause your problem. Also, there a re a number of sensors in the paper path of which one might have gotten stuck. A sensor is a small lever like gadget that is pressed down when paper moves over it. If it remained in the down position for some reason (like removing stuck paper) it will keep on giving the paper jam error
Aug 23, 2011 | Samsung Computers & Internet
When printing, the paper will start to feed and then pulls to the left, wads up and jams. This happens with both Tray 1 and Tray 2.
Hi You have a small paper jam in the front of your machine,
remove all the trays and the toners have a look under the machine in the place of tray 2 you will see a slot that the paper should feed in to. Fold a sheet of A4 in 1/2 lengthways push it in to the slot and with luck it will come out in the machine, holding on to both ends work the paper along the slot moving it up and down until your paper jam come out
if this is useful please rate me.
Mar 08, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
When receiving a FAX or printing a receipt, it repeatedly jams. The paper is found inside the back cover baked into a folded fan shape.
This folded pattern indicates that the jam is being caused by a physical obstruction in the paper path section. I would suggest manually feeding a thick piece of cardstock paper and seeing if you can find the location of the jam, as it is most likely a piece of trapped paper or plastic tab that has come out of its original position.
-David.
Nov 05, 2010 | Brother IntelliFax-2820 Laser Fax
Paper jam in back, accordian fashion, cannot extract lexmark e328
There might be a access door in the back of the printer, remove the door and gently pull the paper out.
May 26, 2010 | Lexmark E322 Laser Printer
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
Paper jams when folding 8 1/2 X 11 ivory paper; less often with white. Tech says it's a paper issue - so whose colored paper (brand) will work - or is it a design flaw?
Is this paper the same weight/thickness as the white paper?
Are you specifying the settings properly as far as the weight and type?
It sounds like the sensors are detecting a double feed(?)
Try different settings for the tray, and even try a different brand of stock to verify.
Apr 29, 2009 | Konica Minolta bizhub C450P Laser Printer
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
Paper fan folds inside the fax machine.
THERE IS SOME THING BLOCKING THE PAPER PATH, MAY BE PAPER OR SOME THING FELL IN THE MACHINE GOOD LUCK BROTHER TECH
Jan 27, 2009 | Brother FAX-2920 Plain Paper Laser
Brother IntelliFax-2820 Laser Fax Logo
123 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
