Question about Lexmark X4270 All-In-One InkJet Printer
I have a line going down the right hand side of the page when I print that I can't get rid of. I have changed cartriges. Don't know what else to do.
  • bmizyank Dec 10, 2009
    How do I do a maintenence check and I have no idea what vis=a computer means?????
  • 128 Answers
Ur heads are out of alignment do a maintence check on system vis=a computer...
Posted on Dec 10, 2009
  • starchild777 Dec 10, 2009
    go to control panel and then to printers and then rt clk on it go to properties and u can figure out it from there i would imagine...
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
Right hand side of page has 1-1/2 inch horizontal streaks down the side
The scanning bar has 28 leds on it and on my 4100 the 6 leds on the right side were flashing on and off,it could be abad connection on that part of the scanning bar caused by a jamed paper.
to tell if your machine is a printing problem or a scanning problem print out the help menu {press the reports key then the 1 key} if it prints clear then every thing with the print cartrige is ok and the problem is in the scanning part of the machine.
Jan 04, 2011 | Brother IntelliFAX 4100 Laser Fax
Printing quality problem.
you might have to change the toner.
also try remove the toner from the printer and shake a little and try printing. Hope should resolve your issue.
May 26, 2010 | HP LaserJet P4014n Printer
Toner is printing on right hand side of each page printed
Most likely it is the drum cartridge. The other causes such as toner on the laser optics would not produce an on again off again print area. It would be blank the entire way down the page. Since the toner prints in patches down the right side it means it is coming from something that is "rotating" and that narrows it down to the drum.
Good Luck and Thank You for using Fixya.
Mar 31, 2010 | Dell 1700 Laser Printer
Blue line down the right side documents
your not getting the cover closed all the way use the scanning software to make the scan go to the border of the paper onlt and then do a view print to be sure it is the correct size.
Nov 13, 2009 | ScanSoft PaperPort Deluxe 9...
I installed a new Lexmark cartridge for printer 2400, it printed out test page and the cartridge is stuck on the left hand side of printer and will not work. The bulls eye diagram comes up says print...
Try doing "start", "control panel" then "click on printers & fax's", & when you get it open to the "icon" that shows your printer", right click on the printer in use icon, & you get the drop down menu", try clicking on "properties", you should get a "pop up box" with a line saying, "printer is busy", & maybe even written several times, click on & delete all of the lines, if that don't do it right away, turn off & unplug ur power cord until you hear a "noise from ur printer", this is "resetting & releasing it", (probabIy less then a minute, maybe even reboot the PC) printer will not print until you get rid of these "commands", I couldn't be more "precise", on getting the "box", to appear, as it will only "come down & appear", if ur having this problem, hope this helps....Don
Dec 03, 2008 | Lexmark Office Equipment & Supplies
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Lexmark X4270 All-In-One InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
