Question about Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum
The vacuum cleaning brush is not spending - Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum
Yes belt probably broken. Also the brush roller heats up on the ends, causing the plastic end cap nearest the belt to melt/weld to the end. It's supposed to spin freely. Also 2 bearings inside tend to become sticky, probably from heat. Next thing you know, the brush roller is seized and will not turn. Probably the whole reason the belt breaks. New belt & new brush roller, 30-35 bucks. It will happen again. Now you've spent almost half what it costs new. Lose the junk. 2 years for a cheap vacuum is the normal life span anyhow.
Posted on Feb 04, 2010
  • 701 Answers
You need to replace the belt. Here is a link to the belt you need and to a manual you can view:
Bissell Lift-Off Belt and Manual
Posted on Dec 11, 2009
How do I clean the brush area after using my Pro Heat?
The brush or brushes (depending on your model) can be removed if needed. Routine cleaning should just require removing hair and debris from the brushes and wiping the area around the brushes.
There should actually be very little hair or debris around the brush roll if the carpets are thoroughly vacuumed by a properly working vacuum cleaner before being cleaned.
Jan 22, 2017 | Vacuums
When operating smells like burnt rubber. Roller brush stopped turning.
Hi leanneaj...
Your problem is caused by hair,strings,etc getting around the beater bar at the ends of the roller where the bearings are and causes it to sease up.
The smell you smelled was rubber burning, the rubber belt that operates the roller brush has burned into...broken.
You will have to remove your roller brush and clean, and oil and then reinstall it with a new belt
Please take time to rate me
Sep 04, 2011 | LG LUV300B Bagless Upright Vacuum
It says to clean brushes and they are clean and it keeps making a clicking sound. Only 4 months old.
You need to remove the brush tray and clean all the parts behind the brush housing.
May 21, 2010 | iRobot Roomba 530 Robotic Vacuum
My roomba 550 keeps making a clicking noise and it says to clean the brushes, even after I do it
Hello, this type of Clicking sound is most likely a loose alignment within the brush axles. There is a particular way the brushes have to go, each in an individual position. Try to tinker around with the position(s), :) lol... this should solve the Clicking caused by miss ~ alignment. :)
Ciao
Jan 29, 2010 | iRobot Roomba 550 Vacuum
Brush does not spin
I thought my belt went bad....which it did, however there was another issue....The brush was not turning freeley, and would hardley turn at all, which caused my belt to go bad. Apparently, there are sealed bearings in the brush that you can not get to. If your brush will not turn, you can either spend some $$ and get a replacement. I opted to spend some time on mine, and soaked it in some Mr. Clean and water. I then sprayed brake part cleaner into both ends, and re soaked it. I then put some dish soap on either end and freed up the bearings. In between each of the steps I described above, I would try to work it by hand. I have not had a problem since, and saved some $$ too! Good luck and hope you get the same results I did;-)
Nov 08, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Brushes won't turn
the mechanisam that makes the brushes spin are broken. take it into a shop dont fool with a roomba
Sep 11, 2009 | iRobot Roomba 560 Robotic Vacuum
Main Brush Failure
first check if the brush motor is turning before you spend money on a new brush roller and belt. remove the belt by unscrewing the screws holding the brush cover ( the part touching the floor ) and slip the belt of the rotor. turn the vacuum on, and the brush on while the vacuum is in a reclined position. if the motor is not moving, you need a new motor.
Jul 31, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Wont pick up
Mine was doing this soon after I bought it. I had to cut the strings, and hair off the brush...cleaned the filter (plastic one) and then it seemed to do better. I still have problems with it getting clogged in the tube once in a while...I usually take a broom stick and push it through...I also have a Kirby, I tell ya I am thinking of spending the money to have it fixed because these cheaper ones aren't very good.
May 04, 2008 | Hoover U5753-900 WindTunnel Bagless...
Roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Dec 31, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum Logo
404 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
