Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
GE Max Dishwasher won't drain
We have a built in GE dishwasher. It came with the house. No manual. It just says GE Max on the front. It won't always drain and the dishes come out with a gritty film stuck to them. I've tried running it through with just hot water and dishwasher soap/bleach and no dishes. It worked fine for a couple of runs, and now is back to doing what it did before. Any suggestions before I pitch this thing out the window?? ;)
I only chose the first product on the list as it won't let me go further without putting something in......
  • 3 more comments
  • Mizzybee64 Jan 21, 2008
    Hey bigg t...
    The water level stays the same. I have the feeling that our dishes are being washed in the same water over and over and over again...ick!!!!
    Any ideas. I've checked all of the other things. We even took the drain tube out and made sure there were no blocks.....
  • oslo Feb 02, 2008
    We have Run the dishwasher- water at the bottom is still left- same level and all the dihses left are wet.
  • Garthspader Feb 27, 2008
    I have the same problem... moved in... no manual... just started not draining all of a sudden. Also having problems with the timer. I press start and nothing happens. You have to open the door for a while til things reset then start again.
  • swordfish1 May 08, 2008
    Sounds like the same problem. Constant level of water left after every wash. Dishes left with a film. Checked the hoses and drain and they seem fine. Had for a couple of years and this just recently started happening. No clogs in the spray arms either.
  • suth Jan 19, 2009
    GE Max worked fine for about 4 years, now there is water left in the bottom after it finishes the cycle. Water level varies from wash to wash - sometimes a little, sometimes full. Checked screens, drain hose nothing seems to be plugged. Ran through cycle several times with no dishes in it. Eventually came through drained. Fine for a short time then back to the same problem. Tried this trick again, but did not work a second time.
I had the same problem with my GE Max model gsd6260k. I could hear it trying to drain and some small amounts of water going into the sink drain pipes but it never emptied it all there was aprox 1/2 inch of water that's 1.25 cm aprox for the metric lovers... lol
What i did was...Clean out all debris that was there.
There is a small basket (aka screen) just behind the bottom arms just a tad to the right i lifed it up enough to get a turkey baster into the opening (drain?). I coudn't seem to find the screws without taking all the bottom apart to get the basket out, as the water line going up the back to the center arms is there. Then i used the baster to remove water and i kept squeezing the air forcefully from the baster into the hole. This help, i don't know if it was a clog or what but i let the tub start to fill with water and then hit the start button again which makes it drain out. It was definately draining faster. when it finished there was no more water in the bottom of dishwasher.
Posted on May 18, 2010
  • 640 Answers
Open the door and look inside the dishwasher,at the bottom you should see a screen/screens.check for any clogs at them.also check the wash arm holes for obstructions.inspect the wash arms for cracks at the seams.run the unit and try to determine the water level on the initial fill,try to notice after a couple of cycles the level stays the same.let me know.
Posted on Jan 20, 2008
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
I have a ge max dishwater that isnt draining
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Aug 03, 2010 | GE 24 in. Profile PDW9200J Built-in...
It will not drain all the way, there is always water at the bottom after a wash and dry cycle?????
Hello. This is a definite issue and somewhat unsanitary so let's get it fixed. Most likely, there is a partial blockage somewhere between the tiny drain pump at the base of the machine and the trap under the sink.
Kill the power to the dishwasher at the electrical panel for the house. Remove the lower front panel of the dishwasher and disconnect the drain line where it connects to the drain pump near the floor. Expect and plan for about three cups of drain water. Disconnect the small pump and visually check it out. If there is debris in there, remove it. If not, keep looking by checking the length of the drain hose and the area under the sink where the drain hose enters the drain and the trap there. J.
Jun 09, 2010 | GE GSD4500G Built-in Dishwasher
Dishwasher will not drain
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Mar 20, 2010 | GE Nautilus 24" Built-in Dishwasher
My ge profile model # gsd5132f02ww is not draining the water.what to do?
Max Power :Most likely You need replace MOTOR/PUMP ASSEMBLY GE DISHWASHER on the dishwasher as it sold asone piece.
Jan 28, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
G E max dishwasher won't drain
It could be a bad water level sensor or drain valve.
Jul 19, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher not always draining
If the dishwasher drains through the vent pipe on your sink it may be clogged. I had that problem as well. Unscrew the vent cap and look for junk. In my case of all things it was dog hair!!
Nov 23, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
Sears Kenmore dishwasher drains and then fills back up.
you have a nearly-clogged u-tube near the connection to your house drain piping. clear the clog out.
May 31, 2007 | GE 24 in. GSD4020Z Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
3,828 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
