Question about Dryers
I was having trouble with the start swith for a little while, now it wont start it at all. I pulled off the start switch and it is working fine. Its a Kenmore 70 series. Thanks Jim
  • jimtyl Dec 10, 2009
    Thanks for your help. I did figure it was the door switch that was not ingaging correctly. I do appreciate your help and input
    President:
  • 1,218 Answers
Good day,
I'll assume you checked the push to start switch with an ohm meter, to determine if the contacts were in fact closing.
Here is the flow of power.
1. The appliance cord (if it in fact is good) supplies power to the the door switch. One of the common causes for not starting.
2. It leaves there, and enters the timer. The timer takes the power, and if in an on position will split the power into 2 lines.
Obviously the timer could be a problem.
3. One of the power lines goes to the centrifugal switch of the motor, but since the motor is not running, cannot start the motor.
4. The press to start switch solves this problem by bypassing the centrifugal switch and starting the motor directly.
Once the centrifugal switch is at speed, the motor has 2 sources of power. That's why you can release the push to start switch, and it continues to run.
A bad motor can create this problem.
5. Broken or frayed wire anywhere in this circuit.
A lot of trouble shooting to do. Simple things first. If gas, plug in another device into that outlet.
Electric, you'll need to remove the receptacle cover and check from center to one end then the other. Both sides should give you 120 volts. CAREFUL, YOUR DEALING WITH 230 VOLTS HERE.
With an ohm meter, check the door switch for continuity.
From there on it gets more difficult. Broken wires being the worse.
Sorry I can't give you a simple answer, but it's not a simple problem.
Jack..
Posted on Dec 10, 2009
Will not start wash cycle
Check the door switch.if the door swith is defective
the machine will not start sometimes you can get
it to start by closing it several times till it catches
but if it completely shot then that wont work you
could pull the plug jump the switch and clost the
door and plug it back in the pause llight should
go out
Dec 13, 2007 | Maytag Neptune MAH6500A Front Load Washer
I just moved and my matag epic z dryers will not start. I have power to the back of the dryer. The power switch feels like it is stuck in......
the start swith is momentry with the switch stuck you woild have to break the the conecton by pulling one wire off the switch and tuching the outher wire momentary do not conect if this works its the switch pull the plug before you trythisthen pull wire off put back the plug then try the test .
Jul 19, 2013 | Dryers
My dryer wont start at all...
Did you check the door switch. If it is open (not making contact) the machine will not run. Could be the motor start/run switch which could be stuck with lint (clean it) or worn out ( replace the motor).
Sep 18, 2009 | GE DSXH47GGWW Dryer
87 Ford F250 turns over but wont start
Fuel cut off switch or inertia swith on passenger side kicker panel, it might have got accidently kicked while getting out.
Feb 02, 2009 | 1987 Ford F 250
Phone will not swith on.
Are your batteries installed correctly? if they are check to see if you have the correct type batterie for that unit, if they are, consult yur trouble shoot section in your manual, if that doesn't work contact the company directly by phone or e-mail
Jan 05, 2009 | Siemens A60
Food processor stopped working
hi there is no reset switch follow these instructions and it suppose to work http://www.useandcaremanuals.com/pdf/FP1300-1400Series791.pdf when you used it did you smell a burned stench? is the unit smells still from it? then probebly the coiles are burend - sorry cant help.... http://www.blackanddeckerappliances.com/customercare/home.jsp good luck
Mar 21, 2006 | Black & Decker FP1300 Quick N Easy Food...
Dryers Logo
18 people viewed this question
Top Dryers Experts
