Question about Williams 2509612 Ceramic Mid-Size Heater
Pilot will no stay lighted consequently the main burner will not remain lighted either unless the knob is continually depressed. To alleviate this, I light the burner keeping the knob depressed and at the same time applying tape to hold it down. I am not sure this is a safe method of operation. However, it looks like a problem inherent with this type appliance. It would appear a class action lawsuit would bring relief to all of us who fail to get relief from the manufacturer or at least assistance. Clint B
    President:
  • 1,515 Answers
Hi, Not knowing the nature of the Law suit, I can tell you about taping down the knob on this valve is dangerous.If the pilot will not stay lit, you must make sure the thermocouple which is located next to pilot flame with the longated bulb on it and screws into the gas valve is tight. Tight at the valve and in the flame. If it continues to go out when you release the knob after holding it down, you must replace it.This is what generates milivolts to keep it lit, and then allows you to turn the valve to on to fire the burners.You can unscrew this at the valve and pull it back out of its mount.By at any hardware store, under $5.00 dollars and replace it. This will indeed solve this problem. As safety to you and you're family, please remove the tape asap. Sincerely,
Shastalaker7
PS Good Luck With you're action.
Posted on Dec 10, 2009
    President:
  • 1,214 Answers
First of all, calm down. This type of problem is typical of many gas appliances.
Are you running propane or natural gas?
Make sure the pilot port is clear of dirt and flows clear. The pilot orifice is tiny, and do not drill it out or anything. Just make sure it's clear.
After you do that, look to see if there is a gas adjustment on the main valve for the pilot flame. It is usually located under a screw on the valve, and the adjustment is actually a screw itself.
Low gas pressure can cause this problem, best seen by watching the pilot flame as the main burner lights. If the pilot flame goes down with main burner light, then it's a gas pressure problem.
If the pilot flame sufficiently covers the thermocouple under all operating conditions, chances are the thermocouple needs replacement (purchased at plumbing supplies or hardware stores.).
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
40,000 btu Charmglo patio heater, brand new, pilot light stays lit as long as you keep the knob depressed. As soon as you release the knob, and turn it to the high position, the pilot goes out! Please...
There is a thermocouple that detects that there is a pilot flame so that main gas won't come on unless there is a pilot. That thermocouple is faulty. These are available from a plumbing supply house. The thermocouple will be attached right in the flame from the pilot and connects back into the gas valve.
Dec 24, 2010 | Garden
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
Not sure how to relight the pilot light. Some point during the night it just went off. Not sure how or why that happened either. I have tried to do a few things but need help
To light your pilot you will need to find the gas valve assembly. It will be a block of aluminum with a plastic knob and a few pipes attached to it. Once you find it, rotate the knob to the pilot marking on the knob. You will know when you are at the proper setting because you will be able to depress the knob into the gas valve about 3/8". Once you do that, there will be a small red button which you can snap causing a spark at the pilot. There may ba a small viewing port covered by a removable metal shield. OK, Depress and hold in the knob, snap the red button a few times. Keep holding the knob in, look into the viewing port for a blue flame. If no flame, snap the button a few more times looking for a spark. Once you see the flame stop snapping but continue to hold the knob in. Count to 30. Slowly let the knob out watching that the flame stays on. If it starts to go out, quickly depress the knob and hold for a minute. If it continues to go out, you have a bad thermocouple and it is not letting the pilot stay lit. If it stays lit, rotate the knob to On. A few seconds later and if the unit is calling for heat, it should light the main burner. If you need a new thermocouple, go to a good hardware store or Farm Center (bring the old part with you) and ask for a new one.
Dec 29, 2009 | Williams 1403622 Gas Compact Heater
The pilot is off and I don't have the manual. How do I start the pilot to turn on the logs
You will need to find the gas valve. Open up the lower section of the fireplace and look foe a small cube of aluminum with a knob on it that says On-Off-Pilot. Turn the knob to the Off position by lining up the word with a small dot or line indicator on the body of the gas valve. Then turn the knob to the Pilot setting. You will know when you are in the correct setting because you will be able to depress the knob into the gas valve body. Hold the knob depressed and click the larger red button. It will snap so don't be startled. Continue to hold the knob in while looking between the logs for a blue flame. If you don't see one, keep snapping the red button. Once you see the flame, continue to hold the knob depressed for 30 seconds or so. Release the knob and make sure the flame stays on. If it does not, repeat nthis procedure and hold down the knob for 45 seconds. If the flame continues to go out, you need a new thermocouple. Once the flame stays lit, rotate the knob to the On setting. The main burner should start within 15 seconds.
Nov 26, 2009 | Leisure HOMEPRIDE Electric Fireplace...
I have an Amana dinosaur model P67470 dual HVAC. It's blowing fine but the pilot light's goine out. I can find the valve but don't know where to light it?
Not an easy one to get to. From the gas valve, follow the small 1/8" diameter (usually copper) line toward the heat exchanger. It will lead to a pilot assembly just over one of the burners. Using a long match or shis-ka-bob stick, hold a flame just over the pilot assembly until you see the pilot light. Remember you will need to have the gas valve knob on the Pilot setting and depressed into the gas valve. Continue to hold down on the knob for 15-30 seconds. Then after the pilot remains on, rotate the gas knob to the On position. Hope this helps!
Oct 20, 2009 | Amana Comfort Zone 12M32PBEH Air...
Lighting the pilot light
The steps involved can vary slightly depending on your furnace model and pilot valve type, so if possible try and find the instructions inside the furnace door cover or in the instruction manual. This is for a gas fired furnace, but applies to any gas-fueled appliance including water heater. Two of the most common types of pilot valve body assemblies either have a red reset button and a gas valve or no reset button and a valve knob that can be depressed. But whichever type you've got, if you have an older model furnace with a standing pilot (flame is lit all the time) then this is the basic procedure.
  • Turn you thermostat to 80 degrees or to a setting that will demand heat. Make sure the thermostat is in "Heat" mode.
  • Go to the furnace and find the pilot valve. The pilot valve body is a box shaped device into which the main gas line will run and is located near the gas burners. It will usually have a gas **** or valve knob that reads "On, "Pilot" and "Off." Locate this gas **** or knob.
  • Turn the knob or gas **** to the "Off" position and wait about 3 minutes for any residual gas to clear away.
  • Find the pilot. It's located near the gas burner tube assembly in the furnace.
  • Get your match or lighter ready. Sometimes the pilot is hard to reach. If possible, try and use a long fireplace match when you light it. If you don't have a fireplace match then a butane BBQ grill lighter works well too. If you don't have that, then you can fasten a match to the end of a stick when you light the pilot
  • If you have a pilot with a red Reset button, turn the gas valve from "Off," to "Pilot."
  • If you have a pilot with no red button, turn the knob from "Off" to "Pilot."
  • Place the lit match or ignited lighter tip at the pilot and depress and hold the button or depress the knob as appropriate. Depress the button or knob for about 30 seconds. This maintains gas flow to the pilot until the thermocouple gets hot enough to open the main gas valve.
  • Once the pilot stays lit, slowly release the button or knob and turn the gas **** or knob from the "Pilot" position to the "On" position. This will ignite the burners and keep the flow of gas supplied as required for the burners as called for by the thermostat.
  • If the burners fail to ignite then it may be because the thermocouple did not get hot enough to open the gas valve. Wait a few minutes and then repeat the above procedure. This time hold the red reset button or depress the knob for about 45-60 seconds.
  • Once the main furnace burners ignite, adjust the thermostat to the desired setting.
  • If you've followed the previous steps on lighting the pilot and it still does not light after, or will not stay lit, then you probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. You'll need a furnace service technician to replace or repair these parts. You may find that the pilot lights, but it is an anemic looking flame. That's a different problem we'll look at in the next section.
  • If the pilot lights but the flame is a weak yellow flame, it will not get hot enough to heat the thermocouple to its set point allowing the gas valve to open.
    A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it. Adjusting the Flame
    There is usually a small screw on the pilot valve body that will adjust the flame. You may have to refer to the manufacturer's instructions to find the screw. Turn the screw as needed to adjust the flame throw. Yellow Flame
    A yellow flame is caused by lack of air and incomplete combustion. It can be caused by a dirty pilot tube tip. Split Flame
    This is caused by dirt in the pilot tube. Take a needle or small nail and gently clean the tube. Flickering or Wavering Flame
    A flame that flickers is usually caused by a draft.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 18, 2009 | Water Heaters
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Williams 2509612 Ceramic Mid-Size Heater Logo
269 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
