Question about Cell Phones
Brush not spending - Cell Phones
  • Mark Egan May 11, 2010
    Check the belt in the bottom of the unit. Do you hear a motor running?
    Sergeant:
  • 279 Answers
Either the belt has broken or the beater bar is stuck. Need to take off the cover where the beater bar is and inspect it-first thing-is the belt there, and if so, is it worn, loose, broken? If you DON'T see the belt wrapped around the beater bar, you need a new one installed.
Hope this helps.
Posted on Dec 10, 2009
I have a Bosch Exxcel 7 1400 express, had F21 error which I cleared but now when set to wash, water comes in but the drum doesn't move.
F21 refers to the carbon brushes in the motor so price new brushes - if you are handy they are easy to fit and not expensive - but if you can't do it yourself i personally wouldn't spend too much on repairing a 5 year old machine
May 04, 2014 | Bosch Washing Machines
I have two Tuscany faucets. One in the bathroom and one in the kitchen. Both are brushed nickel and both are peeling. Is this a normal problem with brushed nickel? I'm looking to get a new kitchen faucet...
Brushed nickel finishes can be delicate. Do not use any chemicals to clean. Use a soft damp cloth. Contact the manufacturer and complain about it. I bet they send you replacements, or simply exchange them for new ones at Menards. Remember, no chemical cleaners!
Jan 16, 2011 | Home
I have a Bissell vacuum #6594-W. The brush bar will not spin. It keeps melting the belt on the other end of the pully...HELP!
Remove the beater bar and spend some time removing the hairs and carpet fibers from the roller. It may take some cutting with a sharp knife to get it all, but with patience, you will have it smoothly rotating again. Test it by holding it just by the metal end and rotating the brush tube by hand. When it spins freely, it's ready to reinstall.
Dec 30, 2010 | Bissell Vacuums
Moter engaging wheels not turning
Hi Jimmy. Does your machine display and flashing lights, if it does, count the flashes between the pauses. This is a fault code. If you let us know how many flashes, we can help you.
It might be a stuck motor brush. Undo the caps and see if either brush is stuck. A light file with a fine file might help. Careful tightening the brush caps as they can crack if done up to tight.
Good luck. Neil.
Aug 02, 2010 | Electric Mobility Mobility Electric Power...
Brush not working
You need to replace the belts. Here are the belts you need and a manual with instructions:
Dyson DC14 Belts and Manual
Mar 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My roomba 550 keeps making a clicking noise and it says to clean the brushes, even after I do it
Hello, this type of Clicking sound is most likely a loose alignment within the brush axles. There is a particular way the brushes have to go, each in an individual position. Try to tinker around with the position(s), :) lol... this should solve the Clicking caused by miss ~ alignment. :)
Ciao
Jan 29, 2010 | iRobot Roomba 550 Vacuum
The vacuum cleaning brush is not spending
Yes belt probably broken. Also the brush roller heats up on the ends, causing the plastic end cap nearest the belt to melt/weld to the end. It's supposed to spin freely. Also 2 bearings inside tend to become sticky, probably from heat. Next thing you know, the brush roller is seized and will not turn. Probably the whole reason the belt breaks. New belt & new brush roller, 30-35 bucks. It will happen again. Now you've spent almost half what it costs new. Lose the junk. 2 years for a cheap vacuum is the normal life span anyhow.
Dec 10, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Brush does not spin
I thought my belt went bad....which it did, however there was another issue....The brush was not turning freeley, and would hardley turn at all, which caused my belt to go bad. Apparently, there are sealed bearings in the brush that you can not get to. If your brush will not turn, you can either spend some $$ and get a replacement. I opted to spend some time on mine, and soaked it in some Mr. Clean and water. I then sprayed brake part cleaner into both ends, and re soaked it. I then put some dish soap on either end and freed up the bearings. In between each of the steps I described above, I would try to work it by hand. I have not had a problem since, and saved some $$ too! Good luck and hope you get the same results I did;-)
Nov 08, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Main Brush Failure
first check if the brush motor is turning before you spend money on a new brush roller and belt. remove the belt by unscrewing the screws holding the brush cover ( the part touching the floor ) and slip the belt of the rotor. turn the vacuum on, and the brush on while the vacuum is in a reclined position. if the motor is not moving, you need a new motor.
Jul 31, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
