How do I format a 4 GB card to work on Vivitar DVR-310? I have tried everything and nothing seems to work. The 2 GB cards won't hold enough audio to record an hour and half band playing gig and I need the larger memory to record the music to save it. Please help
    Brigadier General:
  • 4,090 Answers
This unit will not accept 4Gb cards it is limited to 2Gb
Posted on Dec 10, 2009
Testimonial: "Yes, you answered my question. Thanks so much"
Vivitar dvr 410v3
According to the manual this is al you get:
  • Digital Video Camera
    TV cable
    Strap
    Built-in USB connector
    Vivitar Experience Image Manager software Installation CD
    User`s Manual
So as with most camera a SD card is not included.
You can choose a SD card or a SDHC card up to 16 GB. The 16 GB could be the max, because in the days this camera came on the market there were no bigger cards. Perhaps a 32 GB SCHC will work too.
Please don't try to put in a SDXC card, because the camera will almost certain not recognise a SDXC card.
Nov 10, 2013 | Cameras
I recently bought the vivitar 7024 and bought an sd card lexar multi use 4 gb. For some reason when I take photos and try to look at the pics it says no file exist. But when I take the sd card out and I...
Apparently, you have pics on the camera's internal memory. Your card won't work until those pics are gone. Here's how...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work.
Aug 18, 2011 | Vivitar ViviCam 7024 Digital Camera
My vivitar dvr 310 is saying memory is full when its not. I got new rechargeable batteries to make it stay on longer but nothing is working. Can u help me please.
Remove the existing pictures if there are any then use the camera and format the memory. Even better is to buy a new memory card for it. If it will not format and or work then return the memory card and send the camera in for repair.
Good Luck,
Gil Shultz
Jul 19, 2011 | Cameras
My vivitar 410 is saying the memory is full but it has a brand new sd card???
Hi
There are two Vivitar DVR-410 models. A model released in the early 2000's and a newer version released in 2010.
If you have the the earlier DVR-410 model then it will probably only use low capacity SD cards - e.g. 512Mb or lower. if you are trying to use a higher capacity card on this model it may well show that it is full.
If you have the modern 2010 version of the DVR-410 then it can uses SD cards upto 2Gb and SDHC cards upto 16Gb
You should also check the card you are trying to use is formatted, and the lock switch is not set.
Hope this helps
David
Dec 29, 2010 | Vivitar Cameras
Is the vivitar dvr 530 compatible with sdhc cards
Plug the SD card with contact terminals facing away from battery. It most likely is using internal memory which is much smaller. All cards under 4gb are normal SD. The camera should be able to format the card, or use an adapter and windows will format (default settings).
Jan 03, 2009 | Vivitar DVR 530 Flash Media Camcorder
Help with camera/SD card
Hi - You can download the manual from the link underlined in blue below:
DVR-310
You most likely need to "Format" your new card as per page 20:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Cameras
MEMORY CARD
I had the same problem today with a 2 GB card. I think it may be the size of the card. When I put in an old 32 MB card it worked fine.
Dec 26, 2007 | Vivitar ViviCam 3785 Digital Camera
Vivitar DVR-310 memory card removal problems
If possible try another card and also try the card in another camera to verify where a possible  problem may lay.
I suspect a dud card
but best to check all ways
Oct 16, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
k24674
jasbo
jasbo
