Question about Acer AL2032WD 20" Flat Panel LCD Monitor
Acer AL2002W Monitor
We have 3cords-ac power cable, VGA cable to Computer, and DVI to computer. However, there is no place to fit the DVI cable in the back of the computer.
Monitor was working fine all powered up. We attached a different mouse and all of the sudden the monitor went blank saying "no VGA signal check DVI cable". There is no spot to plug it in and it was working fine before.
We have a DellGX 240 tower. At school and help desk isnt open till monday. Tried to read manual but a little confused. Thanks
For DVI you need to probably upgrade your cheap graphics card, something not that expensive would be a ATI Radeon HD2400 Pro, it'll do. May want to check what pwer supply maybe required on your PC.
Posted on Feb 14, 2008
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
All my wires in my monitor r unhooked where they go can you tell me.
If your wires are unhooked, Usually new monitors wires are colour coded , for example, blue to blue, yellow to yellow etc.
If your wires are not colour coded, There is only one way the wires can go, They won't fit just anywhere. If they fit into one connector, then that will be where it needs to go.
Hope this helps
Mar 13, 2011 | E-Machines T2642 PC Desktop
I am using acer P205H monitor ,when i plug in it will start and shows acer symbol on the screen but goes blank as computer starts ,i checked all power cables they are OK ,and some switches are provided on...
that switches r made basically changing dvi to vga r vga dvi,if that switches r malfunctionig display goes to blank that means if u connect vga system will have dvi
Jan 30, 2011 | Acer AL1916W 19" LCD Monitor
I have just installed a Acer LCD #X223W moniter. What do I need to do to get my speakers to work with it? Is there a missing port or do I need a new cable. This moniter has a HDVi cable but the Computer...
Did you give the correct model of the Acer monitor you have?
When I looked up the X223W monitor, I see a monitor with a DVI-D port and VGA port. Only the VGA cable is usually included in the box. If your computer has a VGA port (most older computers that came with only the video chip on the motherboard), you can either use the VGA cable or get a VGA to DVI adapter and use a DVI-D cable (purchase separately). Alternatively, check the specs of your power supply and available card slots and buy a new video card with a DVI port. If you have only a DVI port on your computer, get the DVI cable (the VGA to DVI adapter would work but isn't a good option).
If I read the specs correctly, this monitor doesn't have speakers. You should plug your speakers into the audio out of your computer. If you use the on-board audio you will see at least two jacks (microphone/line in) and audio out (speakers). Many audio cards and some motherboards come with additional jacks for surround sound so check your system information. Audio extension cables are a cheap solution if the speaker cables are too short to reach to your computer.
I hope this helps.
Aug 05, 2009 | Compaq Presario 5000 PC Desktop
Not working with dell computer
you need a Dvi to vga adaptor available at office Depot or virtually any electronics store you can even try walgreenes late night
Dec 09, 2008 | Acer Professional P211 21" CRT Monitor
DVI connection to DVI port on PowerMac G4
DVI offers better picture quality since no DAC occurs.
But to most of us Analog VGA will do
Rifaa
Aug 02, 2008 | Acer X193W LCD Monitor
With dvi monitor goes black for 2 second then comes back intermittently
To what I understand. Dvi and vga is only applicable to a system or CPU. Sorry if I am wrong.
Tia.
Mar 29, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Acer AL2032WD 20" Flat Panel LCD Monitor Logo
294 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
