Question about Advent 4211c Notebook
Error 0xc000000f can not boot, I do not have install disc and run win xp
  • 154 Answers
When we talk about laptop won't boot up it is a hardware failure.
First of all, most of the hardware failures that are going to be presented in this article require you to disassemble the laptop and work on its internal components. Because of this, you need the required components to take the laptop apart (such as screwdrivers, etc.) and space, lots of space. If you don't have a workbench, then working on that large table in the living room should do it.
Second of all, you need to be extra careful about ESD (electrostatic discharge). Sure, this is important when working with a desktop system too, but you really shouldn't consider this as some sort of overreaction or waste of time. A few anti-static conductive bags should suffice. These are going to be useful when you take apart components from the laptop and you need a safe place to put them down.
If the laptop does not power on using the batteries, then try to power it using the AC adapter. Pay attention and see whether the LED on the laptop lights up, signaling that the adapter was detected. If yes, then your power jack works. If the notebook still does not power on, disassemble the laptop and remove the batteries. Look first for the CMOS battery and take it out.
Your best bet is that the problem is memory-related. What you need to do is re-seat the memory modules. If there are more than one, then try swapping them between each other and try different slots. Try booting again. If it does not work, then try running with only one module - this way, you can tell whether one is faulty.
Disassemble the laptop and remove the HDD, CD/DVD drives, and the modem and/or wireless card(s). If possible, take out the sound card module (if separate). To minimize the possible causes, you may disconnect the LCD panel as well. Try running this way. If it does boot, then try connecting each connector one at a time, booting up in between to localize the problem.
Good luck and take time to do a hard troubleshooting this trouble is not easy as well. You need to be care full in removing the some parts so that the other will not affected and being damaged.
Posted on Dec 10, 2009
I keep getting error code 0xc000000f on my asus laptop and don't have the start up disc
Solved] Fix Windows 8 Boot Error 0xc000000f go here for instructions http://www.smartpctricks.com/2013/09/solved-error-code-0xc000000f-windows-8-a-required-device-isnt-connected-or-cant-be-accessed.html
Sep 30, 2014 | ASUS Computers & Internet
Google com
Possible hdd failure or a damaged file.
Windows Boot Manager
Windows failed to start. A recent hardware or software chance miht be the cause. To fix the problem:
1. Insert your windows installation disc and restart your computer.
2. Choose your language settings and click "Next."
3. Click "repair your computer."#
Status: 0xc000000f
Info: The boot selection failed because a required device is inaccessible.
Aug 04, 2014 | Acer Aspire Computers & Internet
I have installed Win 7 ultimate and after i have installed win xp sp3 in different drive. But now at booting the computer dosent show the operating system choice but instead win xp starts as the default...
When installing different versions of Windows, you must start with the oldest system first.
1. Booting from XP disc, create 2 partitions before installing and install XP to one of them.
2. After XP is complete, install W7 to second partition and after it is complete you will be given the OS System Boot choice at Start Up.
Regards,
Selk
Mar 27, 2011 | Computers & Internet
In my lenovo z560 laptop win 7 working good but win xp not installing. it is very hard problem with me please solve this problem thank you contacat no. 9891870025(Delhi 53)
Enter Bios , Disable AHCI and Enable IDE if you want to install XP
(You may find that configuration in advance settings in BIOS)
Dec 30, 2010 | Computers & Internet
How to reinstall Xp-home on NB205? Currently running trial vers. of Window 7
Have you found Win 7 to be as unstable as vista? I thought so. The trial of win 7 probably deleted XP, so you will either need a factory reset disc or an XP install disc. Insert either into the CD drive and boot from it. Follow the on screen instructions.
Apr 14, 2010 | Toshiba NB205-N210 Netbook
Bootmgr is missing
Run a Chkdsk:
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
OR:
Perform an XP repair:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 07, 2009 | Gateway MT3705 Notebook
"Windows vista booting corrupt"
try to boot ur laptop with disc manager cd or win XP.
if doesnt works then try win 98 cd and delete ur C:/ partiton and install new vista
Apr 18, 2009 | Lenovo 3000 N500 Notebook
Missing or corrupt win/sys32/config/ sys file
The best thing to do is borrow a Win XP cd from a friend and do the following:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re installs the Windows files. This is great because when it works and you don't need to reinstall all your software.
Thanks, Joe
Oct 13, 2008 | Computers & Internet
Fdc corrupted
That error message means. You must have tried to boot up to a floppy diskette. The diskette ( 's ), were made with a defective floppy drive.To re-download the Setup Disks for Floppy Boot Install of Win XP click the link below:
http://www.microsoft.com/downloads/details.aspx?familyid=E8FE6868-6E4F-471C-B455-BD5AFEE126D8&displaylang=en
Option if you have a cdrom in notebook & a real Win XP CD. Put the win xp cd in the cdrom drive. Start the Pc laptop & press the F8 key every two seconds. Windows will display a boot up option menue. Choose the cdrom. Win XP will start the installation.
Feb 11, 2008 | Computers & Internet
Advent 4211c Notebook Logo
441 people viewed this question
Top Advent Computers & Internet Experts
Computer Links
Rajendra Singh
Rajendra Singh
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
