Question about Philips 55P8341 55" Rear Projection Television
Philips 55p8341 wont power on,but when it does come on picture flashes and starts to twist. will come on & cut off
3 Suggested Answers
yankeegurl
  • 121 Answers
SOURCE: cannot adjust colors
sounds like your red tube is getting a short I can post you a web sight and they have used red picture tubes
http://servicemanuals.vstore.ca/
Posted on Apr 23, 2008
Slinteriors
  • 8617 Answers
SOURCE: 55P8341
sounds like the red CRT may be shorted.You can get a repalcement Red CRT at the following link for a very reasonable price. If your not sure which one your model uses. leave them a email with your model number of your set.
Posted on Aug 12, 2008
I have a philips big screen projection tv modul#55p8341 that turns off after being on for a while. great picture and sound
Your horizontal output chip is going bad after it heats up to a certain point it fails and shuts your set down. After a while if not replaced your set will fail to power up at all.
Aug 13, 2010 | Philips 55P8341 55" Rear Projection...
Need the default coloring for the Philips 55P8341 tv
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2010 | Philips 55P8341 55" Rear Projection...
55P8341
Aug 12, 2008 | Philips 50P8341 50" Rear Projection...
No picture no power red button flashes 4-5 times and shuts off
Try unplugging the 3 convergence yoke plugs and then trying to power on the set. The convergence plugs are located on the board on the left side of the tv looking in from the back and they are 3 identical plugs right next to each other they have a R B and G next to the plugs one letter for each plug just remember which plug goes to which location when you plug them back in.
Jul 16, 2008 | Philips 55P8341 55" Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
Pillips projection tv
I HAVE A PHILIPS M#55P8341A THERE IS DOUBLE PICTURE ON THE SCREEN IF YOU HAVE ONE PERSON THERE YOU SEE TWO OF THEM ONE IS RED THE OTHER IS GREEN?
Jul 09, 2008 | Philips 55P8341 55" Rear Projection...
Philips 55P8341 red pic
yes change the coolant, if that doesnt correct the problem you will need a blue CRT
Jun 04, 2008 | Philips 55P8341 55" Rear Projection...
Blinking lights on philips 55P8341
5 volt protection is causing the set to go into protective shutdown. Check for shorted diode 6306. Part#934038020127
or shorted capacitor 2318. or faulty voltage regulator
May 18, 2008 | Philips 55P8341 55" Rear Projection...
Cannot adjust colors
Apr 22, 2008 | Philips 55P8341 55" Rear Projection...
Phillips model# 60p8341
Let me get this straight, you don't have a picture as long as the unit is on, but when you go to turn off a picture flashes? Questions, first how is the picture when it flashes briefly? Is it normal or with colors misaligned? How is the sound? Could be a loose connection or bad capacitor in the video circuit.
Mar 24, 2008 | Philips 55P8341 55" Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
