Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Motor in overheating . I do not find any blocages
    President:
  • 1,214 Answers
The motor overheats because it get's too much air, usually caused by missing filters, or filters that have large tears or holes.
Posted on Dec 10, 2009
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
Dyson smells of burning when switched on then cuts out
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Aug 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
After using the unit for a few minutes it cuts off.
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Apr 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson wont turn on and its a bit smelly
Replacement motors are avaible on eBay2_bing.gif for about £25, however repalcing one requires good DIY skills and tools.
Mar 18, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My vacuum won't pick anything up
Make sure that brush is rotating. Check if you have the right height adjustment. Check for blockage.
You can see instructions how to adjust height and change belt if needed on our website:
http://www.goodvac.com/
http://www.goodvac.com/articles.asp?id=143
Good Luck,
Rocky
Dec 28, 2009 | Kirby G6 Bagged Upright Vacuum
Motor overheats and shuts off
The priamry cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Once a motor starts to overheat, it has already been damaged and even after the filters have been cleaned, may well still overheat and cut-out. The motor has a built in over-current trip to protect itself (and you if it seriously overheated). This normally automatically resets itself, however if the motor has just about had it, the moemnt it is switched on, it just trips again.
Oct 17, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson vacuum cleaner overheated and won't restart
usually there is a onshot TC fitted to the motor once it pops its popped and you have to replace the motor assembly.
Jul 22, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Motor cut out - overheated
Should reset after an hour or so, clean filters and make sure dry first
Nov 23, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction
Sounds like your motor bearings are going bad. This is generally indicated by the motor overheating, and the heat transferring out through the motor pulley, which is where the belt attaches. So, your machine is overheating, melting the belt, and then tripping the thermal cutout. When it cools and you restart it, the belt is no longer functioning due to being melted, and this would make it not pick up on carpet. If you look at the motor pulley and it is turning blue: this is indicative of overheating.
The other possibility is that there is a clog, which is also causing your motor to overheat; so before you throw it away make sure all of your air pathways are clear.
The fact that you've had it 8 years is somewhat remarkable, however, since most vacuums of this type are averaging a 3-5 year lifespan. (And half that for bagless.)
So, check for clogs, and if it's not clogged, you're probably due for a new machine.
-R
Oct 01, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
191 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
