Question about Directed 473T Remote Control
Valet 473T remote
Bought car with this remote in it. You can lock and unlock car, push car start button. Car will try to start 3 times, without success. The dealer replaced the car battery, would this have kicked out the command to start the car, or is it maybe in a service mode so when they did work on it the car wouldn't start accidental.
  • 2 more comments
  • pruittn Oct 20, 2008
    Remote starter will not start since battery was disconnected. It will attempt to start but will not.
  • Charry Hardin Oct 21, 2008
    I have an aftermarket remote starter, I had put on by Ziebart's. My battery died, and I had to have a new one put in. Now Ziebart's says, since I unhooked the battery the starter had to be reset. But they want to charge me $50.00 to reset my starter. I would like to know if anyone knows how to do this, as my doors will not lock and unlock with the remoter starter either.
  • irishpenny19 Jan 31, 2009
    same problem with my 1999 Ford Escort ZX. I don't care about the keyless entry - just the remote start capability.
  • Christopher Renner
    Christopher Renner May 11, 2010
    Tootsie2, can you post the year/make/model of your vehicle?
    It's not in a service mode - on Valet products that feature is activated with a toggle switch and the remote start will not even try to start the car.
    Problem Solver:
  • 6 Answers
It sounds like the system needs tach sensor reprogramming. The remote start system may have a tachometer sensing mode where the system "knows" that the car is running and to stop cranking the starter when when the engine is running. Generally when the vehicles battery is disconnected the system "forgets" the setting of the tachometer at idle which is programmed at the time if installation. Take it to a remote start installation store for this or get a hold of a maual for your system and shouldnt be too dificult to program.
Posted on Jul 10, 2008
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Mar 09, 2012 | 4Button Remote 474P
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
On the remote I will push the unlock button, then the car's horn honks and unlocks the doors. It also honks when I want to lock it. I am only pushing the lock or unlock button once. I'm not in the...
You can disable the chirp confirmation by using the following procedure
1. Turn the ignition on
2. Turn the ignition off
3. Press the valet switch 5 times, wait for the Status Light to flash twice, the parking lights to flash twice and the horn to chirp twice.
4. Press the valet switch 4 times, the MARS unit will respond with 4 Status Light flashes and horn chirps
5. Press the transmitter START button, the MARS unit will respond with 3 Status Light flashes and horn chirps
6. Turn thr ignition on to exit program mode
May 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
Trying to program 474v remote for viper car starter
Super easy
1. Make sure car is disarmed
2. Get in car turn key to IGN position
3. Push valet button one time and let go
4. Push and hold valet button.
5. While holding button push either lock or unlock on keypad of new remote.
6. Siren or horn should sound.
7. Let go of valet button and turn key OFF
8. Test remote
9. Smile and grab a shake ;)
Apr 01, 2010 | Viper Security and Remote Start System...
Disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
Jan 03, 2010 | Astra Car Alarm And Remote Starter,...
How to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Need to upload manual for a valet 473t remote
Here's the user manual
http://www.directeddealers.com/manuals/og/valet/G561R_07-05.pdf
If you need more info call 888-425-8890 for the manufacturers (DEI) customer service.
Aug 31, 2009 | Directed 473T Remote Control
Just bought a used Infinity QX4 with this 473T remote. I can get it to light up the dashboard but that is it. How do you make this thing lock doors and start car
Here's a link to the manual
Here's the DEI customer service number: 888-425-8890
Jun 24, 2009 | Directed 473T Remote Control
Directed 473T Remote Control Logo
1,149 people viewed this question
Top Directed Televison & Video Experts
ted dux
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
