Question about Janome MyLock 634D Mechanical Sewing Machine
Remington my lock 134d...my overlock stitches are opening at the seams...I have tightened the tension but the problem continues. What can I do?
fixitruss
  • 6 Answers
SOURCE: Janome 134D Overlocker
Set you differential at 1.0 and your loopers at about 3-4 the needle thread tensions are usually around 5 to 6.
 I would also suggest that you place four different color threads on machine to make it easier to adjust all. Now if you are using only 3 threads the same applies.
 Also------patience.
Posted on Oct 10, 2007
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
SOURCE: My Lock 134D Lost Manual
Follow the link and you can view the instructions online
http://www.sewingonline.co.uk/instructions/janome134d/
Posted on Jun 30, 2008
SOURCE: mylock 134d janome
hello my name is julia and i do not know how to thread my serger it is a mylock.
Posted on Dec 09, 2008
SOURCE: toyota SL3404D differential overlock
Please i am in need of an instruction manuel for the Toyota SL3404D
Posted on Jul 31, 2009
How can I set the right tension on an overlocker globe lock m-34?
The right tension on an overlocker will vary depending on the result that you want. The standard tension for just a plain 4-thread overlock stitch would generally have all the thread tensions set at the halfway mark between the high and lower number. From that point, you may need to tighten or loosen each thread tension to get all the threads to stitch evenly.
Probably the best advice would be consult your owner's manual. It should have instructions on adjusting the tensions and what to look for.
Another suggestion would be to search YouTube for a video that shows how to adjust overlocker tension.
Nov 14, 2015 | Sewing Machines
What are the settings for overlocking stretch fabrics
For knits with lycra in, you are best to thread up four threads and seam with the 4 thread marrowing stitch like this, preferabbly with ball point needles in your overlocker, size 80. Use cones of polyester thread, 3,000 metres or 5,000 metres rather than normal thread. (Although if you have trouble matching thread colours you can use a small reel on the left needle as this is the thread that will show on the right side of the garment.)
Start with your machine tensions on 5, both needles in and threaded, stitch length of 2.5 and no differential (set it on zero) and test stitch. Using stretch or ballpoint needles is a good idea too to avoid any deflection and skipped stitches. Then practice serging on some fabric scraps, double layer and look at the seam, if it is tunnelling (pulling up the fabric), then move the cutting blade to the left. Test again and if still tunnelling, then loosen off the tension on the top and bottom loopers by a half number and test again.
If the opposite is happening and the threads are looping off the edge of the fabric, then move the cutting blade to the right to trim less fabric, test again. If still too loose, then tighten up the top and bottom looper tensions by a small amount and test again.
You want the seam to lie flat, the two looper threads to meet right on the cut edge and the needle thread to be just visible from the right side when you press open the seam.
There is always a small amount of adjustments needed on an overlocker when setting up for a new project as every fabric will behave differently. Don't tighten up the tension on the needles much past 5 though, or you may get thread breakage.
If you find that the seam is flutting then you can use the differential feed to adjust for this too.
There is some good overlocking info on Debbie Cosgroves website, www.sewing.about.com, with images which may help too.
Nov 07, 2011 | Janome MyLock 634D Mechanical Sewing...
Correct settings for 804dsp serger to sew a sweater.
Are you wanting to use the serger to sew a hand knitted sweater together? or do you mean a sweat shirt knit or other knit fabric. If it is the first option, I'd say don't bother, as you can't do it with the blades working because it will cut your knitting and the wool will unravel in the seams.
If it is the second option then I would start with the following settings.
Four thread stitch, so both needles and the upper and lower loopers threaded. Set tension on all four dials to 5, stitch length to between 2 and 3, and differential on zero. Move the cutting blade over to the right for a wider seam. Now test stitch on some fabric scraps double layer and see what the seam is looking like.
Now you want to adjust a couple of things: firstly width of the seam. Is it the size you want? If you'd like it a little narrower, then adjust the cutting blade back a little to the left to narrow the seam slightly - just depends on the fabric weight. For example if it is a loose open weave like boucle you would want a wide seam to make sure it holds the fibres fully.
Now you can adjust the upper and lower loopers to get the thread wrapping around the edge looking nice. Look at the seam and the fabric inside it. Is it tunnelling and pulling up the fabric? if so, release tension on both loopers a half number to put more thread into the seam. Test stitch again and see if the loopers are meeting nicely on the cut edge of the fabric. Upper and lower looper threads should be meeting right on the cut edge so if this isn't happening and one showing on the other side, then tighten the looser one by half a number and test again.
If the threads are hanging off the edge then you have the choice of moving the blade to the right to cut less fabric off, or tightening up the looper tensions to pull in the thread.
That's it, hope this helps you to master your serger.
If you'd like some images and further explanations of other stitching you can do with your overlocker, then Debbie Coswell has some great information on line at www.sewing.about.com, just search "overlocker" to find the specific pages.
Good luck
Oct 11, 2011 | Simplicity Serge Pro SW432 Mechanical...
How do I set up my babylock serger for a rolled hem? What is the tension to be set at?
I don't know your babylock well, some of these have automatic tensions and electronic stitch selection. But a rolled hem is achieved on any overlocker in the following way; the actual dials and knobs might vary a bit.
Firstly there is a stitch finger that you need to change or retract so that the thread can roll the fabric rather than staying flat. For a normal seam this finger sticks out in the area where the loopers and needle form the stitch holding the cut edge flat until the seam is made over it. But for rolled hems you want to retract this finger so it does roll.
On the Bernettes this is a little lever in front of the stitching area that you pull back to retract the finger. Have a look around where the stitch forms and you should see the finger. Some machines, its a part you change on the needle plate with a screw driver, or just move a switch or lever.
You want the right hand needle in place, remove the left hand needle.
Thread upper looper with wooly overlock thread, this is a fluffy nylon that pulls flat under tension but relaxes and "fills" out once its stitched into place. Gives that lovely covered look you see on shop bought tablecloth edges. Your regular thread in needle and lower looper. Usually cutting blade to the right side as you want it to cut more fabric than in the seam so it rolls under. Now loosen off the tension on the top looper, (I use 2 on mine but this is something you need to finesse with each machine), and tighten up the tension on lower looper, (about 7). Leave needle tension alone.
Now test stitch on your fabric, and finess the upper and lower looper tensions until you get the lower looper thread almost not showing, it should be right up against the needle on the underside with the upper looper thread completely wrapping around top and bottom, pulling the fabric under.a seam like this.
Test stitch and adjust upper and lower looper until this is happening.
Now, turn stitch length down to close up the stitching, probably 1 or 0.8 if you want a real satin stitch look to the hem.
Because of the stitch density this uses thread so do the finessing first, then turn the length down.
That's it! Now right down the tension settings you used and keep handy for next time.
Sep 24, 2011 | Baby Lock Eclipse Serger
I have just been given a huskylock 341. The tension is off. How do I correct this?
Have you used an overlocker before? If not, I'd suggest that you obtain a user manual for it as they are completely different to a sewing machine and at some point you will need to rethread it. You can purchase one from here
http://pages.sewing-machine-manuals.com/173/PictPage/3923709707.html
This machine makes three and four thread seams, which is a combination of two needles and two loopers. For the three thread seam you can use either the left or right needle which gives you different sized seams. For the four thread you use both needles, one goes through the middle of the seam and the other is on the left side securing the seam. tally_girl_70.jpg On most overlockers you are able to move the cutting blade too and this will reduce or increase the amount of fabric being trimmed from the right side.
This page http://sewing.about.com/od/sergersoverlock/ss/serger.htm will give you some general information on sergers/overlockers too.
So adjusting tension is a matter of changing the tension on the top and lower looper threads to close up against the cut edge, or moving the blade over to make the seam a little wider or narrower. You may also need to finess the left needle tension so that the seam doesn't pull apart, I always test serge two layers and then pull open from the right side and see if the needle thread is showing (it will show a little bit but you dont want it so loose that it pulls open. Only tighten the needles in very small increments though, as you'll break threads and needles if you turn them up too tight.
Hard to explain without seeing what your machine is seaming now. But as a rule of thumb, start with all four tension dials (or 3 if doing a three thread seam) on 5. If the tension dials are correctly calibrated then this should give you a pretty good seam. You may wish to lengthen the stitches, I usually work with stitch length of 2.5 (same as your sewing machine stitch length) Stitch length will be a dial on the right side beside the flywheel or in front of the blade area. The blade adjustment should be a little knob near the blade area too. There will be a lower fixed blade and a moving upper blade which sits against the lower one, they work like scissors to trim the fabric. So to adjust the blade, you will need to take the pressure off the upper blade, then wind the knob to move it left or right.
Different weights of fabric will behave differently on the overlocker so you do need to adjust tension for each new project. For example, if seaming a jersey knit you'd use a four thread seam, this gives elasticity and strength and you can join two garment pieces with this seam. You'd probably make a 6mm or 7mm wide seam, the left needle will secure the fabric and the loopers will encase the fabric smoothly while the right needle secures them and gives extra strenth to the seam.
But on organza for example, I would make a very narrow three thread seam using the right needle as the organza will roll inside the overlocking if you cut the fabric too wide.
And on something like curtains I would neaten the edge with a wide 3 thread seam using the left needle to get a very wide seam, the fabric wont roll so you'd need to loosen the two loopers a little to smoothly encase the cut edge.
tally_girl_71.jpg For example, on this image above you can see that the looper threads are laying a little off the edge of the fabric in places, particularly the lower looper, (the side that looks like Y's where you can't really see the middle needle thread), so I would tighten the lower looper about .5 on its dial, then test again.
I hope that this makes sense to you, you will need to test serge, and adjust one dial at a time, test again and look at the result, then maybe adjust another thread until you are getting a smooth looking seam.
Sep 05, 2011 | Sewing Machines
I am doing some sashes for a wedding and i want to know on my serger 14SH654 ultralock how to do a rolled hem
A rolled hem on any overlocker is formed by using the right hand needle only, and the two loopers to form a narrow three thread seam. You also need to retract the seam width finger as Trial2962 said. This is a little finger that sits on the stitching plate and the loopers form the stitching over it. By retracting it, the looper threads can form a narrow seam and in fact, roll the fabric inside the seam. You need to move the cutting blade as far right as it will go so you are trimming as wide as possible from the needle, turn the tension on the top looper rigth down to 2 so it is very loose and this thread wraps around to the underside. And tighten the lower looper tension to about 7 so it hardly shows and sits right up against the needle thread. Adjust and test until you get the seam looking like this, then turn the stitch length dial (on the right side by flywheel) down to 0.5 to close the seam right up tight. Lastly, if you can source it in the right colour, buy woolly overlock thread and run this through the upper looper only, this thread is fluffy and when not under tension, relaxes and "fills" out so the seam appears like a continuous coverage over the fabric.
You will need to practice a few runs and go slowly on corners, a curve is obviously much easier to serge than a right hand cover so if you can, cut the fabric with curved ends, much easier to get a great finish. When you chain off at the end, you need to unravel the tail threads and pull them inside the seam for a few mm with a needle to get a smooth finish, then trim the tail and seal with a drop of Fray Stop.9_26_2011_11_26_51_pm.jpg
Sep 04, 2011 | Singer 14SH654
How do i reduce the width of the stich of bernette 134d overlocker?
Adjust the thread tension holder, and see how that works out, the more twisted in it is, the closer the stitches will get :)
Oct 28, 2010 | Bernina Sewing Machines
Tension problems
start with the bottom- should allow thread to pass freely with slight tension when dangled from the thread. Tiny screw on the bobbin case turned clockwise tightens tension. Next, check upper tension. Thread should pull through with foot down, with good tension. Stitch should 'lock inside the fabric(use two pieces of fabric and make a seam, thread from both top and bottom should be visible when you open the seam.
May 29, 2010 | Euro-Pro Fast and Easy 420 Mechanical...
Janome My Lock 134D normal overlocking required
Typically, set all your tension knobs to 4
Mar 01, 2010 | Sewing Machines
Bernette 134D
Stitch length should be set between 1 to 2.
May 26, 2017 | Sewing Machines
Janome MyLock 634D Mechanical Sewing Machine Logo
165 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
