Question about Dacor ECS130 Epicure Electric Single Oven
Our Dacor ECS130SBK convection oven no longer heats, after using the broiler and leaving the door open.
    President:
  • 1,214 Answers
The element is probably failed. Using an oven in this manner (turned on with the door open) is not good.
The element is replaceable, and will require some electrical tests to confirm the failure.
Posted on Dec 10, 2009
Lancer 92 ecr location
check elements with a multi meter for continuity
Apr 08, 2014 | Dacor Ovens
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
My dacor oven model ECS130SBK is very slow to heat. Sometimes reaching the desired temp. after a long wait. Sometimes it never gets there.
I found the bottom element was not getting any power by using a volt/ohmmeter and a test method described elsewhere. (Shut off power, hold down COOK TIME while turning on power. then within 30 seconds press each mode you want to test and only that element/fan/etc will turn on. Cancels by itself after 30 sec.)
I traced the wire back to the relay (wire checked good) and there was no power getting through the relay although it clicked. Removed the relay board to replace it and found a cold solder joint on the "out" terminal with obvious past arcing carbon. Cleaned and soldered the pin and the oven now works normally.
WHY THE SLOW TO HEAT? The oven turns on all the elements to preheat faster and when it reaches your set temp it beeps and now only turns on the element you selected to maintain the temperature. (Bake or Convection) Our malfunctioning ovens would then cool since the element is not working properly and it must go back into preheat and keep cycling.
BY THE WAY- Don't ever use 4 hours on self clean it kills the boards and/or display. I also put a house fan in front of the oven and blow it into the lower grill to take away some of the heat on the two boards. Learned the hard way!
Jun 08, 2009 | Dacor ECS130 Epicure Electric Single Oven
Oven won't heat
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
Feb 19, 2009 | Ovens
Dacor ECD230 lower over won't heat up after cleaning
Under the panel between the ovens there is a little square box with a reset button on it.
Feb 01, 2009 | Dacor ECD230 Epicure Electric Double Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Dacor ECS130 Epicure Electric Single Oven Logo
435 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
