Question about Seagate STT320000A Travan Tape Drive
Belt where can I buy spare belt for my travan tape drive stt320000A
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 20 Answers
One way is to buy a similar drive on eBay - they can be had for reasonable prices there.
Posted on Jul 21, 2008
I really don't have a problem . I was given a PC , & while checking it out , I found it had a Seagate IDE Tape drive in Caddy . I'm not proficient with computers, I was baffled as to what it is for....
, I hope this helps you out.
it is used to make backups...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Seagate STT320000A Travan Tape Drive
Tip
How to Clean a Travan 40
<p>Travan 40 tape drive, manufactured by the leading data storage and backup device manufacturer Quantum, uses the tape storage business to 40 gigabytes of data. It can be installed on any Windows computer, and works as an additional unit similar to a CD-ROM or DVD-ROM. Like a tape of age, Travan 40 used with the recording heads for data storage on tape. These heads have to be cleaned, and Quantum recommends using a cleaning tape.<br /> <p> <br /> <p>1. Turn on the computer. Remove the cleaning cartridge of your case.<br /> <p><br /> <p>2. Insert the cleaning cartridge into the Travan 40 drive, with the metal plate down. Gently push the drive mechanism that pulls and keeps everything in the device.<br /> <p><br /> <p>3. Look at the LED on the drive Travan, should stop blinking and turns off in about 8 seconds. Note that the LED will remain on the cartridge is used more often than not meant to be used and, if so, remove it and put a new cleaning cartridge.<br /> <p><br /> <p>4. Slide the unit Eject button and hold and pull the exposed sides of the car once the disc is ejected.<br /> <p><br /> <p>5. Record the date on the label of the cleaning cartridge with a marker pen so you can track when your Travan 40 drive yet again and how often you use the cartridge.<br /> <p><br /> <p>6. The return of the cartridge cleaning your plastic box.<br /> <p><br /> <p>7. Repeat the process of cleaning every week if your drive Travan more than 3 hours per day, or every month if you use it with less than 3 hours per day. Clean it twice if you have your computer in an area with a large amount of dust, like a room without air conditioning or a warehouse.<br />
on Jun 21, 2011 | Computers & Internet
Put a tape into tape drive and the will reconize the tape
> the ... will recognize the tape
And how is this a problem ???
Symptoms?
Does it happen to every tape-cartridge, or just "one" or "some" ?
Aug 16, 2010 | Seagate STT320000A Travan Tape Drive
Windows wont recognize drive
ok this can happen if
1. you have two drives and you have not set the jumper to slave on this one
2 you are only using this drive and its not set to master
 the jumpers are have a plastic face that needs to be covered over
the manual will usually explain this further
http://www.harddriveupgrade.com/jumper_pins.shtml
will show you in detail with diagrams
Aug 27, 2009 | Seagate STT320000A Travan Tape Drive
Seagate drive doesn't recognize tape media.
please try to use cleaning cartridge. if tape drive is still in failure. perhaps the heads is bad.
Feb 23, 2009 | Seagate Travan TapeStor Travan Tape Drive
Backup software for certance travan 40?
You will have to load a driver for the Travan drive, if windows server 2000 sees the tap drive you could use NTbackup.exe to configure a back-up here is a link to read more about it. http://support.microsoft.com/kb/237310/
Good Luck
Jan 28, 2009 | Certance Travan 40 GB (stt3401a-sst)...
Driver for Travan NS tape drive?
Hi Nick,
The only drivers that are published for the NS 20 are for Windows NT 3.51 and 4.0. The 2003 and XP versions shouldn't require a driver - they should be able to treat the tape drive as plug-and-play (just like a hard drive) as long as it's plugged into an IDE slot on your motherboard.
For your reference, the following webpage has the drivers that are available for the NS 20, as well as a link to the user manual (near the bottom of the page). The manual includes details about the installation procedure, which does not include any kind of driver. Here's the address:
http://www.quantum.com/ServiceandSupport/SoftwareandDocumentationDownloads/Travan20SCSI/Index.aspx#Drivers
I hope this helps - pleawse let me know if I can be of any further assistance.
Dec 12, 2008 | Aiwa Travan NS 20 (TD-20001) Travan Tape...
Installed identical replacement STT320000A but won't recognize tape
The STT320000A is IBM version? some IBM version STT320000A will rewind the tape when inserted. But It can recognize the media after rewind. If can't, try to used the cleaning cartridge or change one new media. regards
Jul 20, 2008 | Seagate 20GB TRAVAN SCSI 5 1/4 TPE DRIVE...
DLT V4 Driver
Most tape drivers are loaded from withing the backup software. Symantec and CA work like this. I'd start there.
If not you have to start the remote storage service and check in device manager to see what it defaults to and see if will find the device for you.
Chuck
www.SanDiegoFixMyPC.com
May 06, 2008 | Seagate Travan (stt220000a-sst) Travan...
Main drive belt
The belt is old and has stretched.
Jan 12, 2008 | Seagate STT320000A Travan Tape Drive
Seagate STT320000A Travan Tape Drive Logo
167 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
