Question about HP VECTRA VLI8 P3 Motherboard (KZM6120)
Corsa c z18xe engine has really bad flatspots more so when cold and pulling away
  • Semi-Driver
    Semi-Driver May 11, 2010
    What this doing in the category computer "motherboards?"
  • 88 Answers
Hi sounds to me like either the air flow metre or the cam sensor at fault but your better of getting the car pugged into a diagnostic machine which will tel you straight away whats at fault. regards
Posted on Feb 01, 2010
Opel Corsa 1.4 bakkie jerks on pull away and sluggish in performance and cuts out
Add fuel injector cleaner to fuel and see if that helps.
If problem goes away then you're lucky.
If problem abates a little, then fuel injector change may be warranted.
Sep 22, 2017 | Opel Cars & Trucks
2007astra z18xe 1.8 l - really bad brake pedal pulse when applying brake
check bearing adjustment again
check for disc rotor runout as may not be sitting correctly on the hub
Jul 22, 2016 | Cars & Trucks
I want to do any oil and filter change on my 2006 Astra 4 door hatch it is Holden GM model AH CDx it has an ecotec 1.8l unleaded petrol engine
So what is the problem? The new filter for a Z18XE screws directly on to the front of the engine block behind the radiator, and the oil drains out of the drain plug at the base of the sump. The Z18XER only differs in that the filter sits in a round black housing visible from the top right of the engine and is requires a 32mm spanner to remove the cover. The filter is different from that on the Z18XE
Jul 21, 2016 | Opel Cars & Trucks
How to fix opel corsa rough idling and starting problems.
Could be bad coolant temp sensor (common part to fail) that tells ECU engine temp to adjust fuel mix. If it fails it can tell The ECU engine is warmed up when really cold and cause hard starting and poor idle. Could also be IAC or EGR.
Apr 26, 2016 | Opel Cars & Trucks
Where is oil sensor unit located on 2001 opel corsa 1.7 D
I have corsa 1.7d guys it can only start once a day at morning while still cold, but around 11:00 morning at summer time it won't fire up so any help please
Feb 22, 2015 | 2001 Opel Corsa 1.7
What's the timing belt diagram for 2008 Opel Astra 1.8L, and what size wrench?
try looking under the hood there may be a belt diagram , if not try the owners manual orlast look on line for the diagram ,just Google searc it
Jul 15, 2014 | 2008 Opel Astra 1.8
I have a 2006 Honda Accord....its been very cold outside and every morning i turn on the car and i hear a noise..not sure if its coming from the engine...but it goes away after I start driving and the...
When is really cold, and vehicles with non electrical power steering start for the first time after a good period of inactivity the power steering pump tents to wine, that is normal, some other cars or almost all the cars when they pass 100.000 miles develop a little metallic noise that goes away when the oil pump distributes and lubricates all moving parts inside the engine when the car starts first thing in the morning in a really cold morning.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
Dec 19, 2010 | 2006 Honda Accord
1997 Vauxhall Corsa - turns over but does not start when warm
It sounds like the pickup coil in the distributor, when it gets hot, it goes open circuit. Changing the plugs won,t help
Jul 16, 2009 | 1996 Ford Escort 4 Door
Computers & Internet Logo
235 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
