Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Display screen says "Er ff"
For the last few months, I kept thinking the ice was not quite frozen. Today I hear sounds as if the icemaker was trying to pop out ice. The screen then displayed, "Er ff". The unit appears to be on. Lights work, water comes through the dispenser, it's making ice, alarm goes off if door is open too long, compressor seems to come on. The freezer isn't cold enough to keep ice cream frozen. The refrigerator doesn't seem to be as cold as it should. We are one month out of the one year warrenty.
  • ruderboy Jan 21, 2008
    I tried this. There was no ice frozen around the fan blade. However, there was dust. I cleaned this off and the refrigerator started working again. The frightening thing was there wasn't that much dust. I did read online a complaint from someone saying they didn't know they were supposed to keep it 6 inches away from the wall and that they wouldn't have bought this refrigerator because of space limitations. Ours was less than 6 inches, so I will do this from now on. I also read in the manual that not changing the filter on time can effect the quality of ice. Ours is a little overdue. All these things may add up to the error code. For now, it's working. Hopefully, once I replace the filter, I won't ever see the error code again!
    Problem Solver:
  • 9 Answers
LG's bottom mounts have had problems with air leaks in freezer making a iceball right under the evaperator fan actually coming close enough to the fan blades to slow them down or stop them all together also causeing the FFerror meaning the control board is not detecting the normal RPM's you should to keep it cool enough. Suggestion take the back panel off and remove any ice carefully if this be the problem. Make sure all doors are closeing tightly and gaskets make a air tight close.
Posted on Jan 20, 2008
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Refrigerator is making a loud buzzing sound in the freezer compartment. We did see a Er FF error on the display. We cleaned out any extra ice/frost buildup and then reset the breaker. The display no...
check your evaporator fan maybe the fan blade hitting edges or the shaft or bushing has damage cause of buzzing sounds apply lubrication or replace bushing but before you dismantle try to off the unit.
Feb 20, 2011 | LG LFX25960ST Stainless Steel French Door...
H20 dispenser displays er lf
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#
May 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ER FF in display ,DISPLAY IS LOCKED, LOUD NOISE
er ff indicates that the computer on your refrig is not sensing freezer fan operation. a guess as to your problem is that the fan is hitting on ice (the noise your hearing) and teh fan is not able to reach operation speed causing the error code. the fix would be to remove the ice from the fan area either maually or by unplugging the unit and letting it defrost for several hours. also to reset the computer you will neeed to unplug it for a few minutes then plugging it back up. hope that helps thanks Peyton
Feb 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
My GE Refrigerator Clicks for hours but will not start.
Clicking you describe sounds like a bad motherboard. Water dispenser issues have been result of frozen water in the tubing in the bottom of the FF area, which you should not have at the moment, so if it is not dispensing water now I'd check the water valve coil. (there are two coils on the inlet valve, one for the icemaker and one for the water dispenser.)
Sep 26, 2008 | GE GSL25JFR Brushed Steel Side by Side...
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
422 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
