Question about Kenmore Dryers
Won't stop buzzing
When I dry my clothes it finishes drying,but it won't stop buzzing,I'll turn the buzzer off it's still ticking,then I put it on air cycle ,it finishes it's cycle, no more is no more,but this is on every drying. Thanks, Ernie
Electric dryerwon't stop buzzing
Posted on Feb 03, 2010
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
End of cycle keeps beeping even after clothes are finished and removed
this could range from a simple processor hanging problem to a defective pcb
please start from a hard reset by leaving the unit plugged off from wall power for one night
Jul 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
MY AMANA DRYER BUZZES THROUGH OUT THE DRY CYCLE, ER? HOW DO I STOP THE BUZZ
www.ehow.com > Home > Home Appliances > Washer & Dryers
YOU MAY HAVE TO REPLACE THE BUZZER. FOLLOE THE SIMPLE STEPS AND , WHO KNOWS YOU MIGHT MISS THE BUZZUNG SFTER YOU FIX IT.
Dec 10, 2015 | Amana NED5100TQ Dryer
Buzzing sound
USUALLY WHEN MOISTER SENSOR DETECTS CLOTHES ARE DRIED THE BUZZER GOES OFF TO LET U KNOW SO MAY HABE BAD MOISTER SENSOR, UNLESS THE CLOTHES ARE DRYED WHEN IT GOES OFF
Apr 12, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Buzz when clothes are done drying is too LOUD!
The buzzer on your model is not adjustable.
Dec 19, 2011 | Amana Dryers
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    Clothes not drying. need 2+ cycles to get clothes dry
    This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
    Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
    Dryers Logo
    193 people viewed this question
    Top Kenmore Dryers Experts
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
