Question about Sony KDS-50A2020 Television
Sony kds50a2020 tv turned off and now blinking power light
Ok i have a sony kds50a2020 tv and yesterday i cleaned the mirror and lens as the picture was getting dark.i replaced the lamp not even 6 months ago.the tv was working great after we cleaned it .then today the picture just went black and sound was still playing.then it turned completely off.the lamp light is not blinking.but the power light is blinking.mirror and lens were very dirty.
  • 1 more comment
  • dave17wilson Dec 15, 2009
    5 blinks
  • dave17wilson Feb 07, 2010
    it has 5 blinks which i looked up to be lamp driver.but how do i fix this.where is the lamp driver located on this tv and how much does something like that cost.
  • tvtechlady May 11, 2010
    how many blinks?
  • 1153 Answers
SOURCE: No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Posted on Sep 09, 2007
SOURCE: Sony Grand WEGA KF-42WE610
Thank you! It worked!!
Posted on Sep 10, 2007
  • 23 Answers
SOURCE: TV screen went black, sound ok, red light blink 5 times
Be sure its blinking 5 times, count after it cycles the first time through the red lights. If it is fact 5 times, that is a lamp driver error.More likely it cycled 4 times, which is common on this model, if that's the case, then it's the fan. Most likely the large one in the rear...It's an easy fix, just pull the back off and replace the part.
Posted on Oct 01, 2008
SOURCE: 3 year old Sony KDS R50XBR1 suddenly no picture, no sound
MY SONY KDS-R50XDR1 TV ITS PLAYIN GREEN THERES NO BLUE HOW CAN I SOLVE THIS PROBLEM.
Posted on Feb 12, 2009
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
KDS50A2020 When I turn it on it you can hear the
Hello, those sets were bad about the lamp, yes the lamp failing and they didn't break the part number on the lamp is a XL-5200. When I would have calls with this issue, I would say about 75% of the time the lamp fixed it....tks
Nov 04, 2013 | Sony KDS-50A2020 Television
How to clean the project television. There is a shadow
Hello
To clean the lens and mirrors of your projection tv follow up please.
Unplug the TV from the power supply. Never undertake any type of repairs on electric equipment without first disconnecting from power. Take care in handling any electric parts, as some may contain a residual charge that can shock you.
Remove screws from the back cover and connection area of the TV. Be sure to put them in a safe place, or on a piece of paper with notations for where each one fits in the television
Gently remove the back cover. Locate the mirror and three projection "guns," as these are what you want to clean eventually
Use a camera lens cleaning cloth (or other very soft and gentle cloth) to clean the mirror and lens. Gently remove any other dust before closing the TV.
Replace the back cover and screws. Plug back in the power supply
Turn on the television. Check to see that everything works correctly and that your picture is now clearer
Mar 22, 2011 | Hitachi 43FDX01B TV
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
I'm getting the 4 red light blink on my sony R60XBR1. What should I do. I've read to just clean the fan. Is this legit?
Yes this is legit. There's 2 fans and take out the big fan and clean it using a brush or something. I just did yesterday when my TV would not turn on with 4 red blinking light. Now the TV is working like new. Make sure you put everything back including the casing before you turn on the TV.
May 09, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
I have a sony kds50a2020 and the picture is turning green. Replace the lamp like 10 months ago with a new one any answers
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 30, 2010 | Sony KP-51HW40 51" Rear Projection...
Our big screen sony tv stopped working yesterday. The power on light is blinking red intermittently and when you push it, it doesn't turn on-no sound or picture. It will stop blinking red periodically, but...
Please try disconnecting all the cables from the TV including the power cables then reconnect them back after a few minutes. You may also try connecting the power cord from the TV directly to a functional wall outlet. If the issue persists then service will be required.
Aug 27, 2009 | Sony Televison & Video
Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
May 29, 2009 | Sony KDS-50A2020 Television
Sony 57 inch WEGA Projection TV
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
Nov 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony KDS-50A2020 Television Logo
364 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
