Question about Simplicity American Quilter SA2400L Mechanical Sewing Machine
Simplicity snowblower stopped augerin. how do i change shear pin?
Simplicity snow blower
Make sure the motor is off and the key is out. Look on the center of each side of the axle that contains the blades. Rotate the blades slowly until you find the holes left by the missing bolts. stick a small screwdriverin the back of the hole to keep the keyway aligned. PLace the new bolt on the end of the screwdriver ( that should be facing you ). Slowly push the bolt through the keyway until the screwdriver pops out the other end. then attach the nut and tighten firly but do not overtighten.
Posted on Jan 06, 2010
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Jul 16, 2017 | Singer Sewing Machines
Husqvarna snowblower does not go forward. The spring is broken on the belt. How can I fix this?
my husq. snow blower when I put in gear it takes off like a rocket ship how do I get to slow down
Jan 03, 2014 | Sewing Machines
Simplicity americana Model SE3 needs service
I agree, the machine needs to be serviced at a sewing machine shop
Apr 16, 2012 | Simplicity Sewing Machines
We have a Huswana snowblower and the auger does
Sorry, your problem was posted to Sewing Machine category. If you are still having problems, you mnight want to re-submit to another appropriate category for help.
Dec 30, 2009 | Husqvarna Designer I
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Simplicity American Quilter SA2400L Mechanical Sewing Machine Logo
273 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
