Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The door only opens part of the way.When I press the opener it opens part of the way, sometimes 1/2 way others 1/4 of the way.
    President:
  • 3,197 Answers
Check the door springs. Could be one is broken. Also remove the motor unit cover and check the drive gear. This is common when that gear starts to fail.
Posted on Dec 10, 2009
My garage door always stops wnen closing.sometimes it wont open.and sometimes it looks like it has no power at all and will do nothing when i press the control
Jojo, possible motor or control board issue, may have to get a garage door tech. to have a look. Befor you do check the trouble shooting links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Garage Door Opener Repair How to Troubleshoot Openers
Garage Door Opener Troubleshooting step by step
Garage Door Opener Repair Help Troubleshooting Sears PartsDirect
Home Repair Remodeling How to Troubleshoot Garage Door Openers
Jul 02, 2016 | Craftsman Garage Door Opener 1/2 HP Chain...
Transmitter quit working for my 3018,I put in new battery??? still lights red led on it but, not open the door...?
Ken, you may have to reprogram transmitter after battery change, check your manual, if you do not have manual, Google search your make and model# manual.
Garage Door Help How to Program Your Garage Door Remote Control
How To Program Your Garage Door Opener
How to program Garage Door Remote change battery LiftMaster Chamberlain
Programming Garage Door Remote DoItYourself com
May 21, 2016 | Building Materials
My 05 passat will not open some doors sometimes, will open all other times and also will lock all doors except driver door sometimes but other times will lock them all please help? was wondering if it was...
It isn't a key problem, but it's most likely to be a door actuator (motor) issue, if indeed it is an issue.
Many cars these days are fitted with a two stage lock program. This means that the first time the key activates the 'open' command then only the driver's door opens. You have to press the key fob twice to have all the doors open. This is a security feature to prevent potential criminals from breaking in other doors and snatching valuables when you activate the locks. So now the driver has control over one door or all doors, depending on their requirement. On these types of modern systems there is often a method of setting the program to open one then all with the single key press, or all doors at the same time with one key press.
Anyway, just try one press and see if it opens the driver door only and then try two presses to see if it opens the other doors. If it works this way, then it is supposed to work this way.
Nov 15, 2012 | 2004 Volkswagen Passat
Both of my garage open by themselves toghether for no apparent reason? One door is a month old and the other is a little over a year old. I redid the codes on both, but that did not help. Both openers are...
Both being plugged into the same circuit should not be a factor. I would call the manufacturer of the newest unit and report the problem. They may know of the problem.
Dec 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
My opener opens both garage door I only want it to open one
You will need to erase both openers out and recode.
Press the learn button on the motor head until the led light goes out on it. Wait for 2 minutes. ----- Press and release the learn button and then press the button on the remote 3 times and try. Genie openers sometimes take multiple times doing this to code in for some reason. For multiple remotes repeat from -----. For the other opener do the same thing but with a different button on the remote, unless you have a 1 button remote then use different remotes for the 2 doors. Thanks BB
Aug 31, 2010 | Genie Company IntelliCode GICT390-1BL...
I have 2 liftmaster door openers and 1 387lm Wireless keypad.can I program it to open either door?
To program that thing you need to locate the smart/learn button on the back of the opener near where all those white wires go. Press and immediately release this and then walk over and key in any 4 digit code you like and then press 0. The zero acts as the enter button on other keypads.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
Door sometimes stops during run as if sensor is blocked
wipe off the sensor glass with a isopro rubbing alcohol; it should fix it.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door wont close all the way
NOT SURE WHAT UNIT YOU HAVE .
ALL OPENERS HAVE AN ADJUSTMENT TO TELL IT HOW FAR TO GO UP AND HOW FAR TO GO DOWN. LOOK ON THE SIDE OR UNDER A LIGHT COVER.IT HAS TO BE THERE SOMEWHERE
Nov 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Bosch SHY66C05: interlock broken, dishwasher rinse-aid leaks, and soap does not open (sometimes)
door lock is in the wrong position. open door and use 2 small screwdrivers to lever lock to correct position. bend the hook on the cabinet slightly downwards if it is a metal hook
rinse aid and detergent dispensors are 1 item. could well be faulty but can also be module. check you are getting volts to the solenoid at appropiate part of the cycle
Sep 06, 2008 | Dishwashers
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
118 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
