Question about Apple Cinema HD Display30" Flat Panel Monitor
My 23 in. Apple Cinema Display won't start. I've successfully connected the G5 tower I was using with it to a flat screen tv to prove the tower works. Is it a power adapter problem or possibly something else?
  • pauld697 Dec 10, 2009
    Thanks. I wanted to confirm my hunch and this did it (as best as can be done).
  • 495 Answers
It does sound like the power adapter has failed. Maybe a power surge or nearby lightning strike took it out, even while it was idle. Otherwise the screen could be faulty. Most likely the power adapter, this seems to be the case with most Cinema displays (from my experience).I suggest before you just send it out, take it to an Apple store or somewhere Mac Certified and have the power adapter tested before just spending $$ on a new one (Which if there's no warranty or it's expired, can be pricey) Best of luck!
Posted on Dec 10, 2009
SOURCE:
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
The USB/ Fire wire connections do not work with my Apple display
try updating the drivers sounds like a software issue conflicting when putting other connections in
actionman
Feb 22, 2009 | Apple Cinema HD Display30" Flat Panel...
Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Oct 28, 2008 | Apple Cinema Display 23" HD Monitor
Apple Cinema Display 23" HD - Dust on inside of screen.
Well, I pretty much knew that the display would have to be disassembled to clean the dust out. I should have been more specific by asking if the display "could" be taken apart to clean it out, especially since the dust is in between the image and light source layers.
Jan 15, 2008 | Apple Cinema Display 23" HD Monitor
Screen resolution.
Hello there!
It's fortunately quite easy to adjust the resolution your MacBook Pro sends over to your external display.  Try this:
  1. Click the blue Apple icon, at the top-left of your display (while connected to your 23" external monitor).
  2. Click on "System Preferences".
  3. Click on "Displays" in the "Hardware" row.
  4. A display preferences window should now open on each display... one on your laptop, and one on the 23".
  5. In the "Display" tab of this preference window, specifically the one located on your 23" display, should be a list of resolutions available.  Scroll down and select the highest resolution, which for a 23" should be 1920x1200.
This should adjust your resolution to the maximum.  To make these settings easier to get to in the future, check the box in the display preferences labeled "Show displays in menu bar".  You'll see a small icon, meant to look like a display, appear in your menu bar.  Going forward, you can click on this to set/change resolution settings without going through all the above steps.
Hope this helps!
Oct 10, 2006 | Apple Cinema Display 23" HD Monitor
Apple Cinema HD Display30" Flat Panel Monitor Logo
96 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
