Question about GE WBSE3120B Top Load Washer
Final spin cycle problem
If I'm washing a small load everything is fine,but if it's a normal size load or a large load the machine works fine but will not go through the final spin cycle and the clothes are left soaking wet.We thought maybe it was the belt so we replaced it, but it's still the same.Could the new belt just need to be a little tighter or is it something else? Any and all suggestions are welcomed and appreciated.
  • 3 more comments
  • daveyboy43 Jan 21, 2008
    I filled it and set it for heavy load and turned it to drain spin and lifted the hose and it seemed no different how the water comes out. Also it does start on a slower speed for a minute or 2 then it kicks into a faster speed,actually some time it seems to fast.The belt that was replaced was purchased at a hardware store and they took the old belt and used some measuring device and sold me this replacement belt. I'm not sure but it seems like the belt should be a little tighter but the motor is adjusted as much as it can be and can't be made any tighter but it seems like I can push in on the belt to much.I also notice on the sleeve the belt came in it says general replacement belt,not to be used with clutching devices. If the belt was the problem,could it cause this to happen?
    So do you mean if I had the right belt that I shouldn't be able to adjust the motor all the way that the tension in the belt should kick in before it reaches the very end? Can you also tell me what the clutch looks like and is there anything I can look for to determine if it is the clutch?
  • daveyboy43 Feb 10, 2008
    I replaced the belt with an original G.E belt and installed a new motor/clutch assembly but the problem is still there.Any suggestions?
  • daveyboy43 Feb 11, 2008
    Tech 17 could I possibly get the locations of the things you want me to check as I'm not sure what I should be checking.
  • robert samples May 11, 2010
    do this for me fill the washer on heavy load then turn it to drain spin pull up the drain hose and see how strong the water comes out
    President:
  • 1,314 Answers
I agree with the good doctor check the clutch on the pully they are not that hard to change also get the right belt from an appliance repair parts store by your model number with a new belt you shold have some adjustment left on the motor if its the right belt
Posted on Jan 21, 2008
  • 1 more comment
  • robert samples Jan 21, 2008
    yes to the first question to the second its on the drive motor its the piece the belt goes around its gold
  • robert samples Feb 11, 2008
    im feeling like we still got a drain problem here ever had a rubber backed rug tear up in the washer pillow or something like that what i would do is take off the front panel squeeze the tub to drain pump hose then check in the pump with a flashlight to see if any of the impeller blades are broken take the hose off the back of the pump and push a water hose with the end cut off through the drain hose from the pump end to make sure its clear if it does fine on a small load then doesn't do well on a full load sounds like its not getting all the water out on a full fill but its getting enough out on a small fill sounds like a slow drain
    course you can pull the front panel like your putting a belt on then follow the rubber hose from the tub to the drain standpipe of your house drain and check all between when you find a glitch stop you got it
  • 447 Answers
Sounds like maybe the clutch is worn?? Ge has several versions of this washer out some use a clutch and some dont Does yours have a clutch attached to motor or is it a solid pulley? Also GE uses the slow speed to start the spin and then kicks into high one or 2 mins into final spin. Is this noticable or does it sound like it starts slow and then never shifts???
Posted on Jan 20, 2008
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Washer not finishing it's rinse/spin cycle
Run any load - large or the least bit bulky (like sheets) on the "BULKY" cycle. It takes longer, but the machine completes the wash. This shouldn't be the way it works. I love the Neptune TL for its retro look and lack of Maytag's classic big cranky knob. Too bad it runs like ****.
Feb 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Final Spin
could be a clogged water pump. check the filter/pump for dirt and small items, socks, pins, coins,
tnx 4 using fixya,
drcool
Oct 11, 2008 | GE WBSE3120B Top Load Washer
Wont spin
you have to check all the harness connections on this machine and when you realize that this is going to happen often you may want to consider tossing this in a dumpster.
May 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
Overflowed on Large load size
i think the water level sensor tube got filled when you had it on it's side, then after the first spin and drain cycle, the tube was again cleared out and ready for real action.
Oct 29, 2007 | GE WJSR1070A Top Load Washer
GE WBSE3120B Top Load Washer Logo
294 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
