Question about Nikon Coolpix 5000 Digital Camera
Display doesn't show any picture - Nikon Coolpix 5000 Digital Camera
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
How do I get the date stamp to show up on the picture DMC Lz2 ? I've already set the clock in the settings menu. But the date and time stamp doesn't show up on the photo taken.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Aug 14, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
Dropped kodak cx7530, lcd display doesn't work, lights up but no picture
see the video instructional and proceed with common sense and logically. God bless you
Aug 02, 2012 | Kodak EasyShare CX7530 Digital Camera
I have a problem getting the date to show up on my pictures. I always set the date before i take pictures, but it doesn't showup on the pictures.
Sep 15, 2011 | Kodak Easyshare C813 Digital Camera
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Intermatic ET8215C- 7-Day Electronic...
My 13-year old daughter has a pentax optio ls1000 and the display screen is just showing pictures in shades of green. is this a fault or some strange 'mode'?
This is a fault in the LCD itself, and is caused by a problem in the LCD itself or the ribbon attatched to it. Try taking the camera apart and reattatching the ribbon, if this doesn't help, a new lcd is order, which can be purchased from amazon for usually around $20.
May 05, 2011 | Cameras
Nikon Coolpix 5000 Digital Camera Logo
26 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
