Viewsonic Monitor sound problem
Unable to hear sound from built in monitor speakers on Viewsonic model VX1945WM. All sound card drivers are installed with no conflicts. If I install external speakers the sound works. The internal monitor speakers did work at one point but just quit one day. Suggestions?
  • 417 Answers
Hi check the sound cable hasn't fallen out or come loose from the back of the monitor. After this reinstall the drivers for the monitor you will be able to download them from viewsonic if still not working then the speaker jack or speakers are faulty.
Hope this helps
Thanks J
Posted on Jan 20, 2008
What should the connection from my vx2250 viewsonic monitor to my desktop look like?
If your monitor has built-in speakers, you should have a connecting cable with stereo mini plugs on both ends installed between the line out connector (usually green) of your sound card and the audio input connector on the monitor. I have an HP monitor with built-in speakers and that's how it is connected
Nov 08, 2012 | Viewsonic Corporation Viewsonic...
Sound no longer comes out of monitor. I believe nothing is muted. I replaced cable between monitor and desktop. Any suggestions.
You didn't provide a model for your Envision monitor, so I can provide specifics - but here's a few things to try: (1) Start an audio program on the computer (mp3, CD audio, movie, etc. (2) Disconnect the audio patch cable from the computer's speaker jack and plug in stereo headphones. Adjust the volume on the computer's audio control panel to set the volume. If you're not receiving any sound - make sure you're plugged into the speaker jack (this is often the green jack). If you now hear sound, continue to (3). If you are unable to hear any sounds - your problem is INSIDE the computer. More on this later. Continue to the next step. (3) Disconnect the headphones and try the audio patch cable between the computer and monitor again. Make sure you're using a stereo cable - it has 2 individual contact points on the plugs - mono cables have just two. Pay close attention to the jacks if more than one are offered on the monitor (some monitors have power output jacks, etc.). Select the "LINE IN" or "SPEAKER IN" jack on the monitor. Be sure the plugs are firmly seated into the jacks on both the monitor and computer. (4) Check the menu settings of the monitor to make sure that the speakers are enabled (or not disabled as the case may be).
if you were unable to hear audio in step (2) above, there is a problem with the audio circuit in the computer. Some things to check are: Is there a volume knob on the sound card that is turned to minimum? Are (all) the correct drivers installed for the sound card in control panel? Is the sound card enabled? Does the sound card have a problem indicated by an "x" or "!" on the icon in control panel? Many times, "uninstalling" the device in control panel and the "scanning for changes" to reinstall will solve the problem. Other times, it is an output device issue: Have you selected "Speakers" as the output (not HDMI or Digital Audio).
If still unable to get sound working, provide the Envision model number along with computer name & model or the sound card name and model. If the sound is built into the motherboard, provide the mother board name and model. With that info, it will be easier to get the info you need.
Hopefully, you got the sound working with the tips I provided above. Please rate my reply. Thanks.
May 23, 2011 | Envision Computers & Internet
Speakers on monitor are not making any sounds... how do i check
VX2255 does not have built-in speaker, see spec here:
It has built-in webcam and microphone.
Please verify the model.
Oct 01, 2010 | ViewSonic VX2255 Monitor
Hi , I own a viewsonic LCD monitor model va1912w. My system has Windows XP. There is no sound from the monitor even after connecting the sound cable from CPU to monitor's audio jack. I have already...
Try the above link for Vista or XP drivers which may be used with Windows 7 in some cases.
The va1912wb came up when I searched under 1912.
This driver is available directly from the site.
Uninstall the other driver if possible.
Aug 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
ViewSonic VG2030wm speakers not working
you are unable to get an image on your ViewSonic monitor, first check that the necessary cables are attached correctly and that the proper drivers are installed. ViewSonic offers drivers for download directly through its website (see Resources).
Some LCD monitors use a VGA input while others take advantage of the newer DVI interface to provide a connection to PCs (some ViewSonic monitors offer both types). When connecting your monitor for the first time, you'll need the right type of cable for both your monitor and computer. In some cases an adapter may be necessary to convert the DVI signal from your monitor to work in a VGA input on your PC.
Check that the VGA or DVI cable is tightly attached to the back of your monitor and to the back of your PC. Use the small thumb screws on the ends of the connectors to keep everything tightened in place, which will prevent the cable from getting loose.
ViewSonic monitors also use a power cable to plug into a power source. If the power light does not comes on, check that the power cable is inserted fully into the back of the monitor and that it is plugged into a working wall outlet or a reliable surge protector.
Mar 06, 2010 | ViewSonic VG2030wm LCD Monitor
No sound
you need to reinstall your soundcard on the computer
Dec 06, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Drivers cannot be does not recognize monitor
I think after your crash you are missing the drivers for your graphics card and not the display. Check what kind of graphics device you have and see if you can find the drivers for that.
Sep 20, 2008 | ViewSonic VX1945WM LCD Monitor
LCD Monitor's Audio Is Not Working
First.. have you installed the drivers for the sound card.. would check that first.. if that is ok.. then check the output of the computer with another pair of speakers or a pair of headphones.. additionally i would check the speakers in the monitor by connecting to another source.. such as an mp3 player or portable cd player..
Sep 07, 2008 | ViewSonic VX2035WM LCD Monitor
VX1945wm not working
do u know how dissarm it ?
Dec 13, 2007 | ViewSonic VX1945WM LCD Monitor
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Sep 17, 2007 | Liquid Video E15LCD1 15"
Computers & Internet Logo
258 people viewed this question
David Payne
David Payne
