Question about HP Photosmart C7250 All-In-One Thermal Printer
Paper not loading
The initial paper loader that pushes down on the paper in the tray is not applying enough pressure to the paper to make it cath and meet up witht he other rollers I ahve a c7250 all in one
    Sergeant:
    Champion:
  • 240 Answers
If the ADF (auto document feeder) is not picking up the paper, you could try the following support document: (Copy and paste the following link into the location bar of your browser)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01081903&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3382185&lang=en
Posted on Dec 10, 2009
On the laser printer HP 3600n it says it needs paper in tray 2. where is tray 2?
The printer comes with one main tray which is referred to as tray 2. The bypass tray is labelled as tray 1.
Jun 01, 2014 | HP Laserjet P3015X Printer
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
Printer keep saying paper jam
The most common cause is the green paper guide in the paper cassette is pushed towards the paper too much. I am referring to the large one right in front as you open the tray. Move it out towards the front a bit, lessening the pressure that it is applying to the paper.
Oct 12, 2013 | Muratec Mfx-2550 mfx-2550
Manually open dvd tray
Look next to the DVD tray to find a small hole. Once you have found that hole use a small paper clip and straighten one part of the clip. Carefully insert that extended paperclip into the hole, if you meet resistance apply gradual pressure until the tray opens...if the tray does not open...Remove the paperclip end (straighten the paperclip again and reinsert the straight end of the paperclip straight into the hole. Once you meet resistance press gently again, if you feel the paperclip continue into the hole without bending, continue pushing until the try opens. This is the correct way to open a CD/DVD/Blu-ray tray with or without the power on.
If you need further assistance, please ask...
I’m happy to help further over the phone at https://www.6ya.com/expert/steven_142d2a6ad692ab09
Oct 22, 2012 | Daewoo P480 DVD Player
My sony dvp-sr200p, disc tray is not opening?
Hello
Try the mechanical release;
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, apply a little pressure and push. The tray should pop open.
there might be a panel that covers the tray, and you won't see the tiny hole. If that's the case, just use your fingernail to pry open the panel, which most likely will pull out (not off), and you'll then see the hole. Once you push the straightened out paper clip into the hole, the tray should come out enough for you to pull it out the rest of the way.
Sometimes the CD drive doesn't open because the case is misaligned. Try pressing on the center portion of the drive when it is attempting to open!
Apr 11, 2011 | Sony DVP-SR200P DVD Player
Does not always grab paper
try loading less paper in the loader, this will effect how well the printer feeds the paper:) Hope This Helps:)!!!
Jul 24, 2010 | Canon lc730i 21047758 Fax
My paper loader wont accept paper that is to say paper is no log
What I understand the paper tray is installed correctly.
Some machines have push sensors inside the at the end of the tray. Look inside the area where the tray goes in with a flashlight. Everything is mostly black so it is hard to see.
Look for actuators that need to be pressed. Locate the tray end area to see if there is a plunger that pushes in the switch actuator. Sometimes the plunger is missing on the tray, or the slide selector on the tray is not positioned correctly. I cannot see this tray so look for these common areas.
Sometimes you can gently move actuators up and down, and phsyicaly see if they fell out of postion or just completely broken.
Also, paper dust is common in these areas. If the sensor is dusty, the sensors will tell the machine there is a jam, if you can clean the sensors from debris even excessive tonor or developer that falls in these places a lot.
Good luck.
Oct 15, 2009 | Sharp Office Equipment & Supplies
Epson cx11nf paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
Could not pick up papers from paper tray.
1- either the tray is not lifting the paper to meet the rollers ( which may indicate a motor problem) or the rollers are not coming down to meet hte paper (clutch problem)
Aug 30, 2008 | Sharp AL 1631 Copier
I have a problem with my Rimage 360i printer. It's not sliding into place during initilazing and comes up with error message 'printer cant be found' (or along those lines).
To fix the problem check nothing is blocking the printer tray path. Manually pull the printer tray out to the position where it meets the auto-loader, then re-initialize and all shoud be ok.
Jul 11, 2008 | Office Equipment & Supplies
HP Photosmart C7250 All-In-One Thermal Printer Logo
200 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
